Old 09-07-2023, 08:42 PM
Doug Doug is online now
1916 plug in coil
What does these go to?
Cat no 1916 1.4-3.3mhz plug in ant osc plug in coil
Old 09-07-2023, 09:39 PM
old_tv_nut old_tv_nut is online now
If it was just a single coil with a frequency range, I would guess a grid-dip meter; but I don't know what has separate oscillator and antenna coils.
Old 09-08-2023, 08:04 PM
https://www.radiomuseum.org/r/unknow...ands_1914.html
Unelco radio
Old 09-09-2023, 03:11 PM
Instead of the usual band switch they used these to save $$. The door
on top is where you change them.
The ANT coil only lets signals through for its band.
The OSC coil is in parallel with the tuning cap. When you tune the radio
it changes the freq thus station.
Things are very simple hear. A high end set would be VERY complex
& work a LOT better.
BTW IIRC either National, Drake or Hammerlund used plug ins for post war high end SW's.
Old 09-10-2023, 07:11 PM
Thanks for the information
