Old 07-29-2014, 10:40 PM
RCA CTC4B "Gainsborough" picked up in San Francisco
After receiving a much-appreciated tip from another collector, I was able to bring home this 21CT664U set last night. It is missing the back, and the CRT is broken but the cabinet is in excellent condition, except for a drink stain and a couple of thin scratches on the top. The chassis is also nice and clean other than normal dust accumulation. The CRT "was" a 21AXP22A with the code 6048 on its connector, so I am guessing it was replaced after maybe five years of use. So, now I need to start a hunt for a good one.
Old 07-29-2014, 10:48 PM
StellarTV's Avatar
StellarTV StellarTV is offline
Hey Chris, glad you got that! I got a tip on that yesterday, but I just couldn't see driving almost two hours to take a risk on something that was already out on the curb for free with no contact info. Noticed the ad was taken down fast... I had my fingers crossed it wasn't a tanker.... or worse, that person who makes the cat condos with the little dangling catnip mouse.
Way to go!
Old 07-29-2014, 11:40 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Nice find! Rare model.
-Steve D.
Old 07-30-2014, 12:54 AM
snelson903 snelson903 is offline
vary nice , too bad about the crt .
Old 07-30-2014, 07:37 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
That cabinet looks to be in excellent condition. Nice save!
Old 07-30-2014, 12:13 PM
Beautiful set!
If you look in through the neck with a flashlight, you may find the gun assembly embedded into the shadow mask. Looks like it may have been launched forward when the neck snapped.
Old 07-30-2014, 03:36 PM
Ooh, nice! If you run across a stash of good 21AXP22s, let me know
Meanwhile, it looks like my adapted 21FJP22 will work, although I still haven't done any of the color setup, and have various other loose ends to tie up in my CTC-4 restoration.
Phil Nelson
Phil's Old Radios
Old 07-30-2014, 04:02 PM
John Marinello's Avatar
<-- "Byron"
Probably did that while moving it to the curb.
Old 07-30-2014, 05:06 PM
Yah, it sucks to think it may have survived sitting all these years, and then got
broken just recently..... But anyway it is a nice looking set, keep yer fingers
crossed a picture tube will come from somewhere to you...... Good Luck...
Old 07-30-2014, 06:48 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
Nice set
[IMG]
Old 07-30-2014, 06:50 PM
oldtvman's Avatar
I hate that when you can see the after-effect of the gun assembly going thru the shadow mask.
[IMG]
Old 07-30-2014, 08:09 PM
stromberg6's Avatar
Congratulations on a wonderful find!! Hope you can find a good 21AX, but if not, you can drop a 21CY, or a 21FB into the mask and set that up. Need to be sure that the anode connection doesn't arc to the yoke flange, otherwise, a relatively easy install.
Good Luck!!
Kevin
stromberg6
Old 07-31-2014, 02:15 AM
Thank you all for the nice comments, and for the suggestions about all-glass CRT substitution. The cabinet is in such nice condition, I kept looking at the back edges and elsewhere to see if it had been refinished-but it has not!
Regarding CRT substitution, the CTC4's yoke mount is interesting-it appears to be just about held in air by three metal rods that go to cabinet anchor points above and below the CRT near its front. That seems to me to potentially allow a glass CRT to be attached somehow to the front of the cabinet without needing to clamp the yoke onto the new CRT, which would be a big challenge otherwise. In fact, I also have a CTC-5 that may need a glass CRT as well, and I am going to look at similar mounting options for that set's yoke and CRT.
Old 07-31-2014, 10:12 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
Glass tube conversion with pics
http://www.videokarma.org/showthread.php?t=253870
Old 07-31-2014, 10:26 AM
This article describes how I converted my CTC-4 to use a glass CRT:
http://antiqueradio.org/RCACTC-4ColorTelevision.htm
It's not very difficult.
The article isn't finished (nor is the restoration), so I haven't hooked it up to the rest of my website.
Phil Nelson
Phil's Old Radios
