Old 11-05-2012, 08:36 PM
jr_tech jr_tech is online now
If you swap the 50EH5s from right to left, do the symptoms change?
Old 11-05-2012, 10:54 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Last night pulled the chassis. Hooked it up through an isolation transformer, connected a pair of Quam replacement speakers and tried some things. New 50EH5s do nothing to remove hum.
Confirmed with scope that hum signal is present at grids of 50EH5s (volume turned all the way down), and shorting each respective grid to ground completely removes all traces of hum from speaker terminals.
Grounded shield on 12AX7 actually increases hum slightly somehow, and disconnecting tone and balance controls, in order to try and remove wiring which picks up hum is also to no effect. Removing 12AX7 entirely (heater is not in series with 50EH5s) cuts hum level to about half, but doesn't totally remove it. If there is a ground loop here, it's not entirely obvious what's going on.
What did work, is hooking up the entire amplifier, heaters and all, to 120V DC. It's extremely tempting to put a little DC power supply inside the cabinet and call it good!
I think the main problem is that the 12AX7 is grid leak biased, with 5M resistors, and is located about an inch from 120V AC power wiring. There's nearly no shielding in the audio section, and the heater wires aren't twisted. The 50EH5 is also a high transconductance tube, and has a huge 1.5M grid resistor.
Old 11-06-2012, 06:32 PM
Does the balance control work properly? If the wiper arm was open to ground, hum could be induced, and grounding either 50EH5 grid would likely stop the hum in both channels... just another WAG!
Oops! Never mind, I see that you tried it with the balance control disconnected.
Old 11-06-2012, 10:15 PM
maxhifi's Avatar
I substituted a 1M resistor to ground for the balance control, so the 50EH5 wouldn't be floating when I disconnected it. Thanks for your input though, this has got to be something I haven't considered! The stereo sounds good, the hum is inaudible if the furnace is running, i was listening to it for hours last night - recapped the multiplex board and enjoyed some FM stereo.
Old 11-10-2012, 09:09 PM
Beachboy Beachboy is offline
Very interesting console, but it doesn't look like there's much stereo separation, with the way those speakers are mounted so close together!
Old 11-10-2012, 09:47 PM
Someone on freecycle gave me a Delmonico/Nivico of a similiar style. It looks like they were really trying to engineer something to ship as easy as possible. Take the legs off and the unit isn't too big. I don't plan on ever doing anything with mine, besides trying to find somebody to give it to.
Old 11-11-2012, 01:20 AM
maxhifi's Avatar
I guess I like it because it's unusual - I'd have been equally interested in your old JVC
Here in Canada most old consoles are Electrohome, RCA, Fleetwood, maybe a Clairtone, Silvertone etc. There's the occasional Zenith, but this one is something I'd never seen before, so naturally I had to buy it and see what's inside.
I think it's cool how every single component has JAPAN stamped on it, and how they bothered to paint the inside of the cabinet white, but yet didn't budget for a dial lamp. It's neat how they used 50EH5s, and how the stamped metal pieces are different than on a north american made item. I also think it's interesting how they had to outsource a British record player, in a Japanese product! - does Britain make anything at all now? I think it's more interesting as a time capsule of a 60s Japanese expoirt, than as a record player - after all I have a Thorens for that job. That said once the needle shows up I'll still want to use it!
In a way it reminds me of that Bel-Aire TV/Radio/Clock that someone posted about earlier this year, that would be another cool item to tear into and repair.
It's just an oversized table radio with a built in record player on skinny legs. And something causing it to hum a bit too much, but I haven't dealt with that yet. One man's trash, another's treasure, I suppose.
Old 11-11-2012, 10:11 AM
Is that the one with the Japanese changer, that has the oiling tubes?
IIRC, it's simular to the Sanyo mentioned.
Old 11-11-2012, 09:27 PM
I've never looked at mine that close, but that sounds interesting-guess I'll have to take a look as soon as I get the chance.
Old 11-12-2012, 01:33 PM
I thought it was novel, when I first saw one.
The oil port had two plastic tubes, that went to the motor bearings.
Old 11-12-2012, 03:27 PM
The reason for Japanese stuff like this being so small is the space in most of their apartments is at a premium. They don't like big bulky consoles unless they're well off and have space for them. Shipping is another reason like you stated too. That is why they also designed their own color sets, ours were too big. They only made a very few roundies, Sharp made one in the early '60s and borrowed some of RCA's designs to do it (it had a 21FBP22 and a somewhat cloned CTC 10 chassis). Then they made their own stuff for the most part.
I wonder what the little JVC you have would cost to ship? I'd love to take it off your hands.
Old 11-21-2012, 09:35 PM
rcaman's Avatar
rcaman rcaman is offline
i love it and i am a fan of older built sanyo stuff. great score steve
Old 11-22-2012, 01:32 PM
maxhifi's Avatar
thanks!
It's currently waiting for the needle to arrive from VM so I can try out the record player. I've also built a little DC power supply to get rid of all hum
Old 11-22-2012, 02:24 PM
maxhifi's Avatar
thanks!
Old 11-22-2012, 03:57 PM
maxhifi's Avatar
thanks!
