CTC-4, just making sure
Am in the process of finishing off the ctc-4 recap. I ordered 3 film caps for the vertical, .082mf@1250v. the originals were .082 @1000v, these wont be a problem, will they? Im sure they are ok, I am just making sure, I would rather be humble now than down the road.
In short, you're good.
The long explanation: In capacitors the voltage rating is the max you can put across them (before they go "BANG!"). You can always use a higher voltage rated replacement than factory spec, but never go lower.
thanks, I was pretty sure but I don't want to leave anything to chance with this one.
