Old 11-29-2018, 01:03 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
Recommendations for a reliable, affordable DTV converter box?
I have a few Blonder Tongue agile modulators that I'd like to hook into a series of DTV converter boxes to get some over the air channels in my house. Unfortunately, I'm having a hard time finding a coverter box that holds up in the long term. One of mine just died, and the other needs to be reset every few days, or the audio and video will get out of sync.
I'd like to find something that I can basically set on a channel, run through an RCA jack to the modulator, and leave alone. I don't need anything fancy, just basic functions, but I'd like to avoid replacing it every few years.
Any help is appreciated.
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
Old 11-29-2018, 03:26 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
Walmart Ematic. Has the outputs you want plus HDMI...
Old 11-29-2018, 03:51 PM
Phil Phil is offline
I've had 7 Ematics running 24/7 for a long while, 2 years+, doing just what you are planning. No problems. They also have a setting so that 4:3 will actually fill the screen like it should. Doesn't work for all programming, but seems to for most. Now if I could just get late 40's tuners to cope with more signals. I get 52 channels off the air with the Ematics and a four bay bowtie UHF antenna, including 2 which are actually on VHF.
Old 11-29-2018, 04:05 PM
jbattles's Avatar
jbattles jbattles is offline
jbattles
yeah i have two hoked to hard drive full of movies and shows. Awesome boxes.
Old 11-30-2018, 06:32 PM
Dubis7's Avatar
Gotcha. I'll put that down and try and pick up a few. Are those exclusive to Walmart, or can I find them elsewhere?
