Old 04-22-2024, 01:56 PM
jr_tech jr_tech is online now
You missed the minus sign
Pin 2, G1 is -120, pin 3, K is -50 to +67
So G1 to K is -70 to -187, Sams says -172, so that's within range of the SAMS.
These voltages don’t seem correct... according to the 3kp4 data sheet, typical grid cut off is at most -90 volts not -172
https://frank.pocnet.net/sheets/168/3/3KP1.pdf
Old 04-22-2024, 04:47 PM
Thanks, 172 seemed high, but I had no knowledge of the tube spec, so kept my mouth shut.
Still need to hear the results of resistance readings and voltage readings with a good signal to try to figure this out.
