Old 03-29-2016, 04:01 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
1976 Quasar console at a thrift
I was doing my thrift store rounds today, and I spotted this 1976 solid state Quasar set. They wanted $10 for it, and if I had a car big enough to haul it, I would have gotten it. The power switch was broke and it would not turn on, but I'm sure that can be fixed. I called up my TV collector friend, and he said he'd take a look at it.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 03-29-2016, 04:03 PM
TUD1's Avatar
TheUniversalDave1
Here's the inside.
Old 03-29-2016, 05:11 PM
That was made after Matsushita bought Quasar from Motorola and the chassis pretty much looks Japanese. It also looks to have a ton of hours on it; so, hopefully, the CRT isn't toast.
Old 03-29-2016, 05:33 PM
Cabinet is similar to my childhood set, but the controls and chassis are very different.
Old 03-29-2016, 06:06 PM
TUD1's Avatar
TheUniversalDave1
When I first saw it, I got super excited because I thought it was a Motorola Quasar with tubes. Unfortunately, that's not the case.
Old 03-29-2016, 06:18 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Looks a bit like mine, but this one seems to be higher end. Mine is a simple one speaker, knob tuned, BUT the tube is really strong and gives a very good picture.
http://videokarma.org/showthread.php?t=263773
Is that set knob tuned, or is it electronicly tuned, I can't see the knobs...
Old 03-29-2016, 06:37 PM
Set also uses the Zenith style power supply.
Top of line at the time.
Old 03-29-2016, 07:03 PM
TUD1's Avatar
TheUniversalDave1
Again, if I was able to transport sets this big by myself, I would have dropped the $10 for it. It would be fun to clean it up real good and get it working. I should probably also get a tube tester.
Old 03-29-2016, 07:04 PM
BTW what's the board on the bottom of the cabinet between the power transformer and the drawer? My Quasar is from the same years but I'm pretty sure it doesn't have it.
Old 03-29-2016, 08:29 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Remote set too, all right! It uses a two-button clicker in the same basic style that had been in use since at least 1962.
Come to think of it I've seen three-button Quasar clickers, just not nearly as many, so who knows.
Old 03-30-2016, 07:44 AM
Its been years but IIRC the drawer had all the low level stuff &
the center had the sweep ckts. Lower priced sets & the 19"
sets just used the simple & MUCH cheaper pass transistor power
supply all on one board.
Old 03-30-2016, 10:00 AM
Those cabinets were too ornate and were poor sellers. I used to get mailers from the Quasar distributor and they discounted the fancier cabinet sets.
The set shown, is a remote control set.
Old 03-30-2016, 11:50 AM
rca2000's Avatar
rca2000 rca2000 is offline
The last time I even LOOKED into one of those sets....was in the early 1990's !!
I believe that "drawer" has a big module with pretty much ALL low-level ckty...called the "supermodule"...and I think that module on the bottom is the remote receiver. Deflection is on the side module--with the fly in a "can", supposedly filled with oil--and SEALED.. It IS a cold set with a VRT...but I NEVER liked the design of the chassis.....then...or NOW...
This one DOES seem to have a delta tube...I think ALL of the ones I worked on were 100 deg in-line tubes...which did NOT seem to hold up too well...
Old 04-22-2016, 07:25 PM
RCAZenith RCAZenith is offline
That thing has a 75 ohm coax terminal!? I've never seen one of those on a 70's era set!
Sent from my iPhone using Tapatalk
Game Room TV's:
1997 RCA Colortrak 27" Console
1987 Zenith 19" V3912W
Old 04-22-2016, 10:16 PM
MRX37 MRX37 is offline
My CCII from 1976 has 75 ohm coax as well.
