Old 10-03-2016, 11:40 AM
1981 13" Magnavox 13C108?
I picked up this set as a freebee, at the Illinois Antique Radio Club, swapmeet a few months ago. The set is a very low hours, super clean set that has a great picture.
The only issue with it, is when playing a video tape, it flagwaves like mad!
A set built that late should play a video tape with no problem.
I wonder if there's information around about changing the horizontal AFC time-constant.
I appears that the set is all original and never needed repairing.
Old 10-04-2016, 08:16 AM
Yes that should run fine on a VCR. Look for small lytics
in hoz AFC & osc. Also check the power supply. About this
time they had a few european chassii in 13". Only
ever had PS problems for dead set....
Old 10-04-2016, 09:55 AM
The set is modular with the main board that swings down like the older T995,etc. The modules face the CRT. The set seems to have a lot of European parts, but does look like USA built. Standard Coil tuner, etc.
It must've been built when Philips just took over.
I tried it using a DVD and it works fine. I'll put it aside for now, as I have too many projects going.
