little sony dim picture
sorry cant ready the model number but its about 7" diagonal B&W rotary tuners guessing late 70's.
Pic brightness all the way up, get a barely decent pic completely cuts off at anything less than about 1/4 turn on the brightness. Beside a weak CRT (which I have not checked yet) I assume I will need to check CRT voltages for bias settings. Anything else come to mind? Last edited by DaveWM; 07-04-2012 at 04:12 PM. |
Check the CRT and CRT voltages. The CRT voltages need to be very close to what's on the schematic or you may have problems.
http://www.youtube.com/user/radiotvphononut |
here is it, the model number tag is rubbed clean
There's a Sony 5.5" CRT on eBay now, don't know if it's correct for your set or not.
http://www.ebay.com/itm/Vintage-Sony...item4d02a9ab4a And a 9" http://www.ebay.com/itm/SONY-9-CRT-U...item2c51fcb951 Whoops, I see you said it's about 7", well I'll keep looking. |
http://www.ebay.com/itm/Rare-Vintage...item35bc5f55a0
here is is for sale, interesting the CRT looks about as bright as mine. |
Audiokarma |
I can't even see how to take the darn thing apart to check the CRT...
model TV-770
Im going to email you the sams on it, its going to blow your mind
The filament IS the cathode and it uses a little isolation transformer that looks like it may apply the horz/vert blanking too. I see a 1uf boost filter cap that could cause low boost/low G2 It is a unique design thats for sure. There are disassembly instructions in here. |
Just to note so everyone doesnt think were too crazy here....the crt is kinda like a 5U4, The filament is the cathode so they use an isolation transformer much like you would to save a crt with a heater to cathode short. The isolation transformer is driven by the flyback.
I have a feeling this is one of those deals where they crt never goes bad or is always the problem. No way to test it. |
