RCA-built CRT swap
Considering all the different makes of sets that use RCA CRTs, I'm wondering if my 19VLNP22 would be a suitable substitution for, say, a 19VJMP22. Both are inline.
Odds are it will go. I will try to run down the differences but I am
almost 60 & suffer from CRS. Do folks get CRS in Canada ?? Physical differences: Screen size Screen curvature Screen glass transparency, color, reflectivity. Mounting method. Pin out. Socket type, pins or spring contact. Built in degauss shield. Separate focus-G-2 conectors. Deflection angle (overall depth) Electrical: Anode KV rating. Bonded yoke (most modern RCA ) Deflection angle ( different yoke) Most in-lines are the same electricaly. If it physicaly fits & the socket fits & has the same pin-out I would try it. But dont blame me if you grow a third arm or get covered with festering pustules 73 Zeno |
Neither have a built-in degauss shield or bonded yoke, that much I know. The 19VLNP22 is in my 1982 RCA which I just don't care for, but it's really strong so I don't want to part with it. The type of Quasar I want, I saw a video of one with the 19VJMP22, the person who made the video said it is RCA-built.
Its probably a Jap Quasar & I dont remember whos jugs
they used. Could be most anyone. Bottom line gotta check it out in person. 73 Zeno |
during our years of experimenting,we found that if the plug or pins looked the same,the crt would work.made hundreds of swaps like this.rarely did something not work
Audiokarma |
I worked on a Quasar badged set, that also had a GE CRT. I was surprised to see a GE CRT in a Quasar set, as they were never a big supplier of CRT's to Motorola or Quasar. I'd have to look at the type number of the CRT used in the set. |
