Old 03-16-2017, 12:28 PM
tvdude1 tvdude1 is offline
5azp4 crt
I have a NOS 5AZP4 want to sell it but not sure what set they were used in maybe later projection sets? and what to ask for it.
Old 03-16-2017, 12:41 PM
benman94's Avatar
benman94 benman94 is offline
Super Moderator
PM sent.
Old 03-16-2017, 01:17 PM
Tim's Avatar
Tim Tim is offline
If you don't make a deal with Ben, someone on the ETF site posted a want ad for one.
http://www.earlytelevision.org/class...ts_wanted.html
Tim
Old 03-16-2017, 05:37 PM
Thanks Tim he did buy it.
Old 03-17-2017, 09:59 AM
Does this crt work in early Rca projection set without any modification? Has anyone tried it?
Old 03-17-2017, 01:32 PM
benman94's Avatar
Super Moderator
You have to mess with the HV lead; the 5AZP4 has it permanently attached to the tube, the 5TP4 has it free. I've also heard that running one at less than ~35 kV won't give brightness on the same level as the 5TP4, but I've yet to confirm or deny this. It was intended for 40 kV on the ultor.
So in short, NO, you must modify a normal RCA PTU-1 projection set in order to use the 5AZP4.
Old 03-17-2017, 02:09 PM
Electronic M Electronic M is online now
Maybe a SS HV rect tube, add some doorknobs to add another stage to the HV multiplier and a 6BK4 to regulate the HV and you could get stable 40KV.
Old 03-17-2017, 02:23 PM
benman94's Avatar
Super Moderator
I actually have the correct RCA projection unit for this set. TSL-86, if my memory of the model number is correct. Throws an 8 by 6 picture. My 5AZP4 is dead
I'd give my eye teeth for one of the big theater projectors with the 7 inch tube. Runs around 50-75 kV if I remember correctly
Old 03-17-2017, 03:28 PM
Tim's Avatar
Tim Tim is offline
According to the spec sheet, this CRT requires air blowing directly on the face to dissipate the heat when run with the average anode power over 9W.
https://frank.pocnet.net/sheets/049/5/5AZP4.pdf
Tim
Thread Tools
Display Modes
