Old 03-17-2017, 01:54 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Gutting Sprague cans
I'm experimenting with a method of re-stuffing cans that doesn't mangle the crimp edge (much) and hopefully will make maintenance easy. Anyway, once I got the grounding rings and wafers out and removed some black material that came out in pieces, I ran into a really hard, black layer that I can't even melt, at least not without extreme heat. Am I going to have to heat them with a blowtorch or drill them, or is there some kind of trick to it?
Old 03-17-2017, 08:56 AM
How thick was the wafer? they are usually are as thick as the bottom bump in the side and have a black rubber sheet in them to act as a seal. Once you get the wafer and terminals out you should see the bottom of the plate/dielectric roll (and possibly tar). If the roll ain't loose I use a cork screw to remove it.
I gave up trying to un-wire and un-crimp the bottoms a good while ago....I kept getting bad cuts on my hands doing the un-crimp plus all the un-wiring/rewiring is tedious. What I do is on cans that have a cardboard sleeve is pull off the sleeve, cut the can off ~1/2" up, drill ~5 VERY small holes through the wafer, for the leads, install new caps and reinstall the cardboard sleeve(can top optional). Cans without cardboard I like to use metal foil duct tape to rejoin the can top. Under chassis cans I don't bother with the tops.
Old 03-17-2017, 11:06 AM
Jon A.'s Avatar
Yup it must be tar, it's as tough as nails. The wafer is the same thickness you mentioned, and there was a layer of plastic film between the phenolic material and the decayed rubber.
Aw, screw it... I'll probably just mock up new cans from stainless steel pipe and end caps. I hadn't thought of that before. My goal is a high-grade restomod; I don't feel a need to make things look totally original.
Old 03-17-2017, 06:07 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
I've been wondering if one could make an un-crimping tool, if you will. Basically like a can opener, except intead of cutting, it would gradually straighten out the crimped edge. Of course, that's slightly complicated by the fact that the crimped edge has legs protruding from it.
And then you'd need another tool to recrimp it.
Old 03-17-2017, 06:51 PM
Notimetolooz's Avatar
Do you have a Dremel tool? One of the cutter bits should get through the rubber. The aluminum cans are soft and easily damaged.
Old 03-17-2017, 08:27 PM
Jon A.'s Avatar
No Dremel tool, but there have been many times I could have used one. I've had a Dremel 219 speed control box for ages; it would be nice to find a Dremel tool it is meant for.
Old 03-17-2017, 08:49 PM
I hold one of the legs with Pliers and heat the can over the stove, it does have to get pretty hot, and you need a Potholder or Gloves to hold it but eventually it will loosen enough for the guts to slide out.
Old 03-18-2017, 01:13 AM
Jon A.'s Avatar
I tried something similar: I put them upright on one of the burners on top of an extra foil burner liner. They didn't smoke much but it was enough to set off the smoke detector which is hard-wired to the building, argh. It's tricky to even make toast the way I like it because of that thing.
Come to think of it they might not smoke if I use your method, I'll have to give it a go.
Old 03-18-2017, 02:04 AM
Findm-Keepm's Avatar
Followin' the Rules...
Years ago, there was a Geocities website a Ham in Texas put up showing how he re-stuffed can caps. From the pictures, he appeared to be elderly, so no surprise that with the demise of Geocities, the website disappeared.
http://www.geocities.com/siliconvall...stom/index.htm <- from my 1998(ish) Netscape (4.0) bookmarks.
He used a lathe and/or a larger tubing cutter (like the ones for larger diameter copper pipe) to cut the can off as close to the base as possible. From his pix, the cut was about 3/4"-1" up from the bottom (mounting surface). A sharp twist then separated the two halves, and after cleaning up the base, the upper part was chucked in a lathe and bored out. The caps were installed on the base, and he slipped the cover back on using silicone rubber and a jig to support it while it cured. He then slipped an aluminum sleeve over the old cap, concealing the joint, and giving him a blank slate upon which he put a label.
I wonder how Hayseed Hamfest manufactures his - over on ARF (and in a thread on AK) the question was somewhat answered that his caps are NOS can caps that he emptied and populated with miniature electrolytics, and then placed a a deep-drawn aluminum or plated brass tube over the guts with a paper sleeve if needed.
Brian
USN RET (Avionics / Cal)
CET- Consumer Repair and Avionics ('88)
Old 03-18-2017, 10:17 AM
Wonder if the wayback machine caught that site?
Old 03-18-2017, 10:25 AM
Naw, I checked first. They don't even have my old Geocities site - it was a huge (100MB!!) datasheet compilation - mostly obsolete Motorola stuff. Back then, the only datasheet sites were pay-as-you-go, so I built my own. I had a whopping.......172 visits in 2 years
That reminds me - I have a buddy that had his business website on AOL neighborhood, or whatever it was called. When they killed that, he and I spent an evening recreating his single page site with FrontPage. 12 images, none bigger than 320x400, and a pageload speed of 1.3 seconds@56K. Amazing - his business grosses high 6-figures, and he still has a one page website....
Brian
Old 03-18-2017, 02:59 PM
Jon A.'s Avatar
It's a real time saver. Like a resume, too much fluff and it would be dismissed without being read. I miss sites lite that; easily handled by my Pentium 166MMX with 64MB RAM and Win98SE.
By the way I've seen those Hayseed Hamfest caps, I really like the look of those.
Old 03-18-2017, 10:06 AM
dtvmcdonald's Avatar
Tip on capacitor cleaning out: the black tar is easily dissolved in toluene or xylene.
In the paint section of big-box home stores its called "xylol". This is good
for removing the last bits of it.
Old 04-19-2017, 01:44 AM
Jon A.'s Avatar
I recently gutted an even bigger can from a Zenith upright chassis without much trouble. The guts came out much cleaner as well but no tar was used in manufacturing. This time I just let it sit on its side in a foil pan on the stove on medium heat, turning it occasionally. It's a real arm/hand saver, worked a treat and there was no smoke; of course I wasn't burning a hidden phenolic wafer this time.
I had acetone for another project and used it to help clean out these cans. My experiments moved some of the mess to the outside of the cans so I may have to wait a while for an opportunity to try the Xylol.
Old 04-20-2017, 07:17 AM
drdave3 drdave3 is offline
I have a few nos can capacitors, if you need one and can give me dimensions.
