Old 03-30-2016, 03:40 PM
TUD1's Avatar
TUD1 TUD1 is offline
TheUniversalDave1
My 1983 Zenith 13" portable
I've had this TV for many years. I got it at a thrift at least six or seven years ago, and today, I decided to unearth it and put it back in service. This TV is not nearly as heavy as the 1976 CCII.
"If you wish to make an apple pie from scratch, you must first invent the universe." -Carl Sagan
Old 03-30-2016, 03:50 PM
I've got the knob tuned version in gray, and seen a varactor continuous tuned version. It is a 9-160 set.
Old 03-30-2016, 04:45 PM
TUD1's Avatar
TheUniversalDave1
I'm having a very annoying problem with this set right now. It refuses to pick up the channel 16 UHF signal from my Blonder Tongue agile modulator. I have a UHF antenna installed and all my other TV's are fine.
Old 03-30-2016, 06:10 PM
MRX37 MRX37 is offline
Looks like it's picking up something. those waves... RF interference?
Old 03-30-2016, 06:22 PM
TUD1's Avatar
TheUniversalDave1
No, the 1976 Zenith worked fine when it sat there.
Old 03-30-2016, 08:29 PM
The 1983 model is not a 9-160 set. It's too new and it uses a large main board and a separate smaller HV and PS module.
Old 03-30-2016, 08:34 PM
The set looks like a remote set. Check to see if the band selector switch is in the proper position. If set in the cable position, it disables the UHF tuner.
Old 03-30-2016, 08:37 PM
TUD1's Avatar
TheUniversalDave1
I already checked all that. They're all in the normal/UHF mode.
Old 03-30-2016, 11:33 PM
Probably uses a 9-181 signal module and a 9-186 HV/sweep module. I have the knob-tuned version and they are good sets. They are indeed a lot lighter than the older CCII sets because these don't have a power transformer and there is no metal chassis in the newer sets.
Old 03-31-2016, 01:30 AM
Mine is a 9-160 set (I had the 9-160 board out of it for a transplant experiment a few days ago), but probably is a few years older. Mine looks identical to the OP's, but is knob tuned and lacks wood grain....They must have kept the cabinet design around a while.
Old 03-31-2016, 09:35 AM
9-160 based 13" sets started in L-line late 1979
its the 1980 model year. Used M & N line also. May have
spilt over to Y line but dont remember.
O-X are skipped over, any sets in that range are house
sets & not part of the regular line.
9-181 sets came in Y-line 1983 model year.
Again there may have been spill over.
If the AFC is in normal & the band switch is in air it should work.
You could also try it in special, that gives wider range
& longer search time for the AFC. Also try a VCR & see
if ch 3 is working.
If a 9-160 set on the 9-160 there is a little transistor called
32 V current source that will do this. Then look for PC cons
in the tuner area that is part of the 9-151 board.
On 9-181 sets tuner is separate. A little taping around may find
the problem.
Old 03-31-2016, 10:25 AM
I think I've only seen one 9-160 set that was made in '83 and it was a System 3 25" console. I've seen plenty of 9-181 sets that were made in '82 for the '83 model year.
Old 03-31-2016, 12:50 PM
Does it receive a good channel on say channel 3 or 4? If so, I've seen sets that won't lock onto a channel if you turn the set on first and then the channel "transmitter".
Maybe the set's PLL circuit needs a tweak.
Old 04-02-2016, 09:53 PM
TUD1's Avatar
TheUniversalDave1
By pressing Enter and using the channel buttons to fine tune, I can tune in channel 16. But when turned off, it resets and you have to do it all over again. What gives?
