Old 04-04-2024, 03:42 PM
mzeitlin3348's Avatar
mzeitlin3348 mzeitlin3348 is offline
LG TV does not power on
I have a LG 65UK6090PUA television which no longer turns on. It worked flawlessly (covered outdoors) for years until today.
When I use the remote to turn it on, the TV displays a red LED at the bottom of the screen which blinks 3 times then stops.
Anyone have a similar LG TV and fixed this problem? I read it is likely the power supply board or it could be the LED backlight or even the main board.
The power supply board replacement is about $40 and would be worth doing if that is what is most likely the cause.
Krell KCT & 400cx FPB
Sonus Faber - Amati's
Old 04-04-2024, 08:26 PM
damen's Avatar
damen damen is offline
Most LGs I run into with this symptom turn out to have bad LED backlights. Usually in a dark room, plugging in and turning on the set you can see a momentary flash on the screen if they are the problem.
Old 04-11-2024, 03:31 PM
I did not see any "flash" of the logo or anything. I just get the power LED blink 3 times (red). I replaced the power supply with a new one - no change.
