Identifying Sears TV from 1976
I picked up this cosmetically challenged but promising Sears black and white TV from 1976 recently. It says it's "Made in Korea" so it's probably a Samsung but is there a way to make sense of the inscrutable model number format Sears loved to use for everything?
The 562 is the supplier ID number...There are online directories of suppliers by ID number.
A note, that supplier isn't Korean. It is Asian. And well known. (Tokyo Shibaura).
I'm so used to late 70s 13" black and white sets like this being made by Samsung. |
Yup Toshiba. At the time they sold Toshiba, Sanyo & Warwick.
Toshiba was the best, a solid set. Main problem with most was on early production sets. They had double sided PCB's & the feed throughs would get intermittent. Caused all kinds of symptoms. They fixed that later. Just slap it & watch on ! 73 Zeno LFOD ! |
Audiokarma |
