Old 12-15-2017, 03:18 PM
stromberg67's Avatar
stromberg67 stromberg67 is offline
Question Telematic color jig help
Hi, I was generously given a Telematic/RCA color jig, and found two wires on the yoke adapter Molex connector broken from the pins . The colors are orange and gray. Can anyone identify which pins those wires go to ? Crude hand drawing attached. Thanks, Kevin
File Type: jpg Telematic Molex Cable yoke adaptor (Medium).jpg (27.2 KB, 26 views)
Old 12-18-2017, 09:29 AM
Hey Kevin,
I don't have specifically the info you're asking asking for, but have you seen the below ARF thread? Can you tell anything from the pictures Brian(Findm-Keepm) posted? Otherwise you could look at the wiring on the back(inside) of the jig connector, because I would think everything would follow straight through. Otherwise drop Brian a line and I'm sure he can set you straight.
http://antiqueradios.com/forums/view...p?f=3&t=308119
Old 12-18-2017, 11:59 AM
Thanks Kevin. The ARF post is a big help. After the holidays I'll open the jig and compare the wiring on the female Molex. Shouldn't be too hard to figure what's what. I also have a CK-3000, but no adapters for that one. Many for the RCA.
Thanks again!
Kevin G.
