Zenith TV parts score
Hi All,
I came across a tube caddy filled with Zenith TV parts. Looks to be some early transistor stuff. There are modules that are made on strip board, IF strips, some IC's etc. I am looking for a list of Zenith part numbers so I can figure out if these are useful or if they go off to the dump. Thanks! |
Nice! Have any vertical output transformers in there?
Honey, turn on the tv.. I'm cold! |
Given box size they are probably all for CCII generation sets (mostly deltagun CRT, and made from 73-78) an possibly some of the monochrome sets that predated the color sets in going modular.
Search CRSP here to find the cross reference book.
Make a list of part numbers & post it. There are some parts
in demand from that era such as 9-57-VCR 22-5001 800-860 800-616 and HV triplers. It does look like 70's stuff. We can point out more with part ##'s. Any kits ( 800-### ) are usually good if complete. BTW if you have a 9-57-VCR I need one to re engineer. Its a blank PCB with a 9-90-## board piggy backed on it. Its used to make some chassii work correctly with a VCR. 73 Zeno LFOD ! |
Any 9-181 or 9-186 System 3 parts?
Mom (1938 - 2013) - RIP, I miss you Spunky, (1999 - 2016) - RIP, pretty girl! Rascal, (2007 - 2021) RIP, miss you very much |
Audiokarma |
Amazing find!!
I will make a list of what parts I have. I would much rather get them to someone that can use them rather than dumping them.
