Old 05-10-2024, 07:57 PM
damen's Avatar
damen damen is offline
The CRT filament usually shared its power transformer winding with the 6BK4 high voltage regulator tube. There was usually a .1 cap to ground from the semi- floating filament circuit. When needing an isolation transformer because of a heater to cathode short in one of the guns, removing that .1 did help with the smearing issue sometimes.
