Old 05-04-2004, 02:50 AM
Shain's Avatar
Shain Shain is offline
Just a question.....
Is there any reason you can't use a baking soda powder and water mixture to remove battery acid?
I've done it hundreds of times to car / motorcycle batteries and connection cables.
Old 05-04-2004, 07:28 AM
heathkit tv
Guest
Posts: n/a
Dunno about cleaning circuit boards, but as for removing crud from car batteries.....not only will baking soda work, it'll also neutralize the battery if you allow any of it to get inside....so be careful!
Believe it or plotz, but warm water or even Windex do a great job of cleaning batteries....mebbe the vinegar or ammonia in some Windex-like products is the culprit in this case.
Anthony
Old 05-04-2004, 08:45 AM
Chad Hauris's Avatar
I think the vinegar method is useful where alkaline batteries have leaked inside a device...the electrolyte is a base rather than an actual acid as in a car battery.
Old 05-04-2004, 03:24 PM
kby's Avatar
kby kby is offline
batteries
Car/boat batteries are lead/acid technology; the electrolyte is sulfuric acid.
Alkaline cells used to used a potassium hydroxide solution (I think) as an electrolyte (basic).
A battery for an old radio is more likely carbon-zinc, which used ammonium chloride or zinc chloride solution as the electrolyte (weakly acidic).
The thing you're trying to get off, though, is probably not just dried electrolyte, though (especially not with a car/boat battery), but the reaction products of the electrolyte + whatever it spilled/leaked on, e.g. copper or brass contacts, wire, etc.
Old 05-05-2004, 02:02 AM
kc8adu's Avatar
kc8adu kc8adu is offline
i bet the thompson club will be at indy this year.
if you know which values you need i can send some your way.
and to clean up the board use a desoldering station or a solder sucker and clean off the solder.wire brush scrape or sand the traces/leads and resolder.
gotta clean off the battery juice to stop the corrosion though.
email for more info
Old 05-05-2004, 10:51 PM
Paula's Avatar
Paula Paula is offline
Originally posted by kc8adu
i bet the thompson club will be at Indy this year. if you know which values you need, i can send some your way.
So far, I haven't been able to find any that even approach the smallness of these.
Paula
Old 05-05-2004, 11:50 PM
Old 05-06-2004, 09:03 PM
kc8adu's Avatar
the ones i have and used are a near perfect replacement other than all being radial.
when i get done with hamvention i will try to get some dug out.
that 4.7@35 you have in the pic is a beercan compared to the ones i used.
email for more info
Old 05-06-2004, 10:07 PM
Paula's Avatar
I won't hold my breath
Old 05-17-2005, 07:44 PM
catlover32 catlover32 is offline
Originally Posted by Sandy G
Sinclair ! Dino the Dinosaur ! Oh, man !! My family & I went to the NY World's Fair in '64, & I remember the Sinclair people had a booth where they'd blow this piece of green goop up into a Dino & give it to the kiddies. I was 7, & right in the middle of a serious "dinosaur phase"- seems like I bawled my way into 2 or 3 of 'em. Wonder if there are any left now? I also remember seeing myself on a RCA roundie in the Disney pavilion, I think, in Living Color, except my & everybody else's face was kinda purplish. -Sandy G.
Have you ever clicked on: <http://www.sinclairoil.com>? They're still active west of the Mississippi and have a merchandise page...
Thread Tools
Display Modes
