Reproduction Back for Admiral Models 19A1X & 17T1X
Phil Nelson's recent 19A12 restoration showed a superbly finished Bakelite cabinet, but the back was missing. Since I have an almost-identical back for a 17T12, I thought I'd try to do a reproduction that would fit Phil's set. The only difference between the two cabinets is the rectangular cutout for the 17T12's Rotoscope antenna.
![]() All modesty aside, it turned out great. The tools were simple and the materials were cheap. All I used was a saber saw, electric drill, sanding block, ruler, paper, and patience. And a 35-year old Black and Decker Workmate. The original material was Masonite, a composite wood product first used in the 1920's. Home Depot calls it "temp board," and others refer to it as a variety of hardboard. One side is smooth and burnished; the other side has the imprint of a screen. A 2x4-footx1/8-inch piece cost about eight dollars. ![]() To make it appear authentic, it has to look machine-cut. To be sure all the holes lined up perfectly, instead of tracing it directly on the Masonite, I made a paper template. Then I triangulated the hole circles to get each hole center placed perfectly. I used a small drill bit to mark the hole centers through the paper. Tracing complete, holes marked, and ready to cut: The next challenge was to get cleanly cut holes and edges. After some experimentation I rejected the sawblade and drill bit that I would usually use. For saw-cuts and drill holes without furry edges, I used a scroll blade and a "brad point" wood boring bit. The holes measured 11/32 inches, and I had to go to a woodworking store to find bits in 1/32-inch increments. That was another four bucks. The brad point bit will cut a clean circle it's run at very low speed. I made the holes at about 100 rpm. If it ran much faster than that, it would tear the wood fibers on the surface and leave a fuzzy hole. Also, the point of the bit is excellent for accurately centering the hole. Here's the finished product. Since I had the original power cord, I tried to make a metal interlock bracket. The result was only fair, so I temporarily positioned it for this photo. This is a comparison of the original with the reproduction (I later drilled the one missing ventilation hole and the hole for the top middle screw so it would fit the 19A1 without a Rotoscope antenna). ![]() Total cost was 12 dollars, but I still have plenty of Masonite to replace the damaged back on this Motorola 12T2 with 1,700 holes. And after that I'm going to climb Mount Everest in shorts, a T-shirt, and flip-flops. If you know anyone who needs a back for an Admiral 17T1X or 19A1X, here are links are for a template in two parts. If the Flickr download in original size is used, it'll give you two JPEGS which, when printed on letter-size paper, will give right-side and left-side prints that can be joined to make a perfectly-sized paper template. https://flic.kr/p/WEYyor https://flic.kr/p/WP6rU7 -Winky Last edited by Winky Dink; 07-18-2017 at 11:59 PM. Reason: Renewing dead links |
That's looking good. Lots of patience lining up and drilling all of those holes
Outstanding work
I need three of these backs and was gearing up to do the same experimenting you did including trying a variety of drill bits. You just saved me a lot of time and effort
Very nice job! I need to make a couple of backs, too, but I have been holding off because I didn't want to make something with fuzzy edges and vent holes.
Phil Nelson |
Excellent job.
[edit] Was just thinking, since they likely didn't have CNC routers or laser cutters back in the day, I suppose the originals were made with a stamp and die set. I don't know how else they'd of mass produced these. Last edited by Kevin Kuehn; 09-07-2012 at 06:32 PM. |
| Audiokarma |
That's a beautiful job. The tough part of these is making them accurately, and you solved that by triangulation. I copied the layout picture for future reference. Thanks.
Reece Perfection is hard to reach with a screwdriver. |
