Old 07-17-2016, 04:19 PM
SwizzyMan's Avatar
Restoring an admiral c322
CTC-4 Director 21
just picked up this nice CTC-4 director down in West Palm. The set has a big history and has been heavily modified. This set originally came from Connecticut. It was acquired by its previous owner (he was a repairman) when a customer decided that the set was too expensive to get repaired and they left it. It eventually moved down here to Florida. The previous owner was an experienced Ham radio operator. I was invited to take a look around his house while we were picking the set up, his house was full of receivers and a couple FM transmitters he built himself with many other pieces of tube equipment. I originally heard about this set through my wanted ad in the classifieds here. The original price was $6000 BIN and $3000 to bid on it. Eventually, it made its way to $500 after I offered $500 for it. The first thing that I noticed when i saw it on ebay was that it had a glass 21FBP22 instead of the original 21AXP22 crt. This didnt bother me much at all. While it may decrease its value, the FB will have a much better chance of surviving all these years without leaking. I was able to test the CRT today and the results were a bit discouraging, the cutoff on almost all the guns was just barely under the box on my CR-31A, and to make matters even more confusing each gun tested fine for a few seconds on the tester, but then the needle starts swinging erratically and upward. I thought I read somewhere that these results may indicate a gassy tube, but this doesnt make any sense since I can get a full raster, but the tube seems kind of dim and the red color seems to the least bright of the three colors. I'm not sure if I should zap the three guns with a rejuve or what. I ran the set for about five minutes monitoring the current draw just so I could get a baseline. I got a decent black and white picture, but when I turned the color on I got a lot of interference in the form of small streaking horizontal lines. I also noticed the colors are pretty rough with no signs of light blue and pretty dim reds. At the end of the five minute run I heard a loud pop (sounded like a firecracker).Current draw stayed fine. I immediately shut the set down. I think a paper cap finally gave out causing the loud pop. This is going to be a long project , but I think I can handle it.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 07-17-2016, 04:21 PM
SwizzyMan's Avatar
More photos
Old 07-17-2016, 04:40 PM
wiseguy wiseguy is offline
you should Discharge the HV from the CRT completely before testing on a CR-31, this would cause Erratic Testing, the pop you heard could have been a HV discharge to chassis Ground since its been modified for a newer tube, I went thru this on my ctc-4 before the CRT got rebuilt when hawkeye was in business, there is also some mods in the Gun Drive Circuit to make these newer tubes "run" correctly, color Temp is a bit different
Good Luck!
Old 07-17-2016, 05:13 PM
The loud pop could easily have been a HV arc from the anode button to the shield (where somebody has made a big cutout in the shield). In fact, in your 5th photo there's what looks like an arc track from the button to the shield.
"rejuvving" the jug should be the absolute last resort.
Old 07-17-2016, 07:26 PM
Definitely do not rejuvenate the CRT at this point. Too easy to kill the tube, and what you're seeing on the screen may be normal for a CTC-4 that's chock full of bad caps. A working television will tell you more about a CRT's condition than any tester.
I agree with old_coot88, that pop sound could be arcing, and the cutout in the CRT metal retaining ring is an obvious place to look. If you run the TV briefly in a completely dark room, you might even see the zap occur along that dark track seen in the photo.
When I installed a glass CRT in my set, I made a smaller cutout in the ring, but I also covered the nearby edges with cambric insulating tape rated for 90KV. More about all that in:
http://antiqueradio.org/RCACTC-4ColorTelevision.htm
You are right to think of this as a long term project. Be patient and it will all get done. CTC-4s don't come along very often, so enjoy working with this one while you can.
Have fun!
Phil's Old Radios
P.S. What's in the little metal project box? Looks like a relay and a tube on top . . . ?
Old 07-17-2016, 07:38 PM
SwizzyMan's Avatar
Have fun!
Phil's Old Radios
Thanks Phil! I'll try and keep watch on that area suspect to arcing. The little project box is actually a soft start module. It lets the tubes fully heat up before applying any voltage to them. The same concept is shared on your CTC-7, but this was one of the modifications the previous owner installed. I think its pretty nifty!
Old 07-17-2016, 08:31 PM
SwizzyMan's Avatar
Cant tell if this is a HOT cathode current meter or what. I dont think it is since the meter only has a range of 10 MA and normal cathode current is atleast 100MA.
Old 07-17-2016, 09:38 PM
It could be a cathode current meter with the appropriate shunt resistance in parallel with it to scale the current it receives to the appropriate range...
Old 07-17-2016, 09:57 PM
Cant tell if this is a HOT cathode current meter or what. I dont think it is since the meter only has a range of 10 MA...
That meter is one milliamp full-scale. So it's probably wired to measure the HV regulator current. If it's measuring H.out cathode current, it'll have a low value shunt across it.
...and normal HOT cathode current is at least 100MA.
Normal H.out cathode is closer to 200 ma.
Old 07-18-2016, 07:11 PM
SwizzyMan's Avatar
I wonder if the CTC-4 has those pesky HV issues like the CTC-5 does? I really hated dealing with that in my 5. And how is its performance? Hopefully better than my 5 too.
Old 07-18-2016, 07:35 PM
miniman82's Avatar
First Light: 1952-2011
5 is the only one with weak HV, you won't have any trouble getting a full 24/25 KV out of this set.
Evolution...
Old 07-18-2016, 09:00 PM
SwizzyMan's Avatar
I was doing another current monitoring power up to keep an eye on the possible arcing area from crt to yoke shroud/housing. I discovered something very interesting and possibly damning. There is a strange orange almost neon-like discharge between the very edge of the internal coating to the shadow mask assembly im assuming in the crt. Now I dont suspect this to be oxygen molecules since the color of the discharge is orange not purple, but could this mean my CRT is in trouble? I don't think the tube is gassy since I can still get a nice, bright and full raster on the screen. I've noticed the glow kind of likes to jump around like some neon bulbs do (like electricity in a decorative neon flame bulb trying to find the path of least resistance). This is concerning me since I have never EVER seen anything like this. Your thoughts?
Old 07-18-2016, 11:58 PM
ohohyodafarted's Avatar
Bob Galanter
Contrats! Appears to be a rather nice set condition wise. Although, I feel it's shameful that it has been butchered with an all glass tube. Just my personal opinion; as I feel that the real reason to own an early color set is to have the original rare metal crt and be able to see what an actual color picture looked like back in the day with a 21AX.
BTW: if you should decide to convert this back to the correct 21AX crt, I have a purity ring and the plastic insulation shroud from a ctc4 I would be willing to sell.
ME http://AntiqueTvGuy.com
Old 07-19-2016, 06:14 PM
miniman82's Avatar
Same here, came on a spare jug I bought and I don't need it. Got the metal parts too, they aren't hacked.
Evolution...
Old 07-19-2016, 06:21 PM
SwizzyMan's Avatar
As soon as I get some money. I'm buying an ax if I can even find one. I really wish I had an ax for this set. But can anyone answer my question on the reasons for the orange discharge in my glass 21FB?
Thread Tools
Display Modes
