The Deep (c. 1979) T-127 (E-180)
Dances with Wolves (c. 1990) (T-182) Quite long movies!!!! -- The longest I have @ the moment is 172 Mins (THE GREAT ESCAPE) and its excellent!! Look @ these 300 minutes tapes,WOW!!!!!!! (It says currently out of stock but Im sure they might get more (If someone sells them)) www.amazon.co.uk/dp/B00005K47G 5 hours in SP mode -- WOW!! |
That is amazing!
The longest tapes I have are radio shack T-180 recording tapes (=3HRS SP, 9HRS EP) which I used to buy annually to keep up with cable while on vacation in an area that is lucky to have OTA reception....9HRS times 2-4 VCRs makes for plenty to look forward to upon return. If you look at lengths of Reel To Reel audio tape and the run time breakdown at various speeds, and factor in auto reverse it is staggering how much audio one could fit on a single audio tape.
TDK also made a 180-minute tape. Here's mine.
Punctuation: the difference between "help! murder! police!" and "help murder police" |
BASF still makes a T-200 length.
I've been buying my new, blank tapes, at the thrifts. I only buy the better quality tapes, by the better makers. I leave the el-cheapo ones for someone else. They're all t-120. Generally, 50 cents each. Even cheaper with my seniors discount.
Audiokarma |
Keep in mind those extended times are for PAL-SECAM systems that run slower at 50 Hz/25 frames per second. Knock off about 20% of that time for 60 Hz-30 frame per second rate.
Those E-180 tapes got a lot of mistaken attention back in the early 1980s as well when people thought they were "3-hour" tapes. If I remember right, they are about equivalent to a T-130.
E-180 do play for 3 hours--Well, In the UK they do!
E-240 play for four hours SP and 8 LP..... |
The Lonesome Dove mini-series was released on a 6+ hour tape in SLP hi-fi.
Let me live in the house beside the road and be a friend to man. |
Audiokarma |
The longest I ever use is T160.I never tried anything longer and I probably alittle larry on using the thinner tapes in my vcrs .They will have a snack on them like the 120 minute cassettes in the cassette players usually have.
How is the drop out rate with those extra long tapes? In my movie collection I cant recall what was the length of the tapes are.Thanks for some of the info with the movies.I probably have some of those movies in my collection.Its hard to keep track of 1000s of video tapes. |
The later radio snack brand T-180 tapes I used had very few dropouts...They were better than some (the bad day at the factory ones) of the shorter tapes I used in terms of number of dropouts over the complete run time.
I have a box full of DF-300 DVHS tapes here, they are the equivalent to (S)T-150 length (or 150mins in HD recording mode). DVHS tapes were apparently available up to DF-480, or (S)T-240! I think SVHS tapes were available at those lengths too.
DVHS got caught with the same marketing problem as Betamax did. The tape length is based on the recording time for standard definition content, which is the same physical speed as VHS LP mode... making DVHS decks the only JVC built VCRs that records in LP mode. :P |
On the old Philips Video 2000 format you could get up to 16 hours on one tape in LP mode (8 hours on each side). Possibly the most of any format?
Wow 16hrs in LP?????
Man oh man.... |
Audiokarma |
Thread Tools | |
Display Modes | |
