Old 07-17-2018, 07:02 PM
Sealtest Sealtest is offline
RCA tube set with no picture and a strained flyback
I got this 1955 RCA tube set from the original owners who had kept it all these years. I tube went bad years ago so the tv got put away. Anyways this set seemed like a good first project but things have not been going well at all. When I first brought it home I could actually get a white box to appear on the screen, so I want ahead and tested every tube. It had a bad verticle output tube that was replaced, and a bad audio 6av6 tube that is still missing (Kinda forgot about it). I replaced every capactor and had hoped all would be well, but no. The flyback has a low pitched whine and the screen does not light up at all (though the rear of the tube does). I can get an arch off of the top of the flyback tube and the plunger, but still no luck with the screen. I will pull the chassis out again and look through the manual again but nothing has been obvious.
I was hoping this would be an easier project to learn from. I repair solid state sets all the time but these tube sets have been a struggle.
Old 07-18-2018, 12:53 AM
The whine is likely the horizontal osc being off frequency. Most RCAs had an adjustable H osc coil. If that coil was adjusted to compensate for failing capacitors and you replaced those caps then it has to be readjusted for the new caps. Best to adjust it with an oscilloscope (I look at the sync on the composite video then match its freq in the osc, then get osc the waveform right).
If your set has an Ion trap and it has been removed or misadjusted that will result in no picture. Another cause of no picture is incorrect gun voltages on the CRT (may want to check).
Old 07-18-2018, 01:20 AM
Is there way to get around using Ann oscilloscope? I do have one, though it never has worked right. I did mess with that control and had no luck. I’ve been at it for over 12 hours now and honestly it’s been frustrating. I’m about to go off to college and have wraped up almost every project besides a few troublesome tube sets.
How do I check for an ion trap or check the gun voltages? Sorry for the questions but I’m a bit new to tube TVs. I’ve been doing solid state and vintage audio but the one thing that never works out is any all tube tv.
Also would these things cause the crt to not light up at all? I’d feel way better if the crt lit up.
Old 07-18-2018, 10:29 AM
Notimetolooz's Avatar
The CRT voltages are usually show on the schematic or tube voltage chart.
Basically the voltage between the cathode and first grid (control grid) has to be in the right range, grid not too negative but not positive with respect to the cathode. Also the second grid needs to be a couple of hundred volts positive.
Ion traps are used on some CRTs in the earlier years. They resemble sheet metal clamps on the neck of the CRT near the socket. Do a search in the forums here for further info.
Don't get too wrapped up in working on this, you will only be running in circles if you do not have enough info.
Do a search for RCA Tube Manual RC-22 pdf and download it. That is the 1963 edition. RCA Tube Manuals have a section on how tubes (including CRTs) work. A good place to start. I've downloaded some other editions but the search function doesn't work well.
With RF circuits you almost always are working with sine waves so a scope doesn't help much. With TVs many areas require the right wave shape so a scope can be very useful. One with a vertical bandwidth of at least 5 MHz is recommended.
Old 07-18-2018, 02:08 PM
Some RCA schematics have adjustment procedures that assume you don't have a scope... Consult your copy of the sams for the set for that...IIRC it varies from chassis to chassis.
If your college has a tech/physics major/minor they probably have scopes that you may be able to get permission to use. May be worth it to bring the chassis if you can't finish it.
Everything I mentioned in my first post is a possible cause of no screen light...so is a dead CRT, but I assume you have tested it.
Old 07-30-2018, 09:18 PM
I do have an update on this set. I spent hours trying to adjust it with no luck, but something interesting did happen. After shutting the set down and walking away for a while, I powered it back up. The flyback sounded like a modern tv and the screen lit up, then as the set warmed up it went back to the normal darkness. It really has been a frustrating project.
I have not tested the CRT yet actually since it did used to kinda work and my CRT tester never has an attachment that works. Yesterday I did get 4 different CRT testers in various conditions so they need to be tested.
Also I got a few oscilliscopes. I see test points in the schematic but am not sure how to actually do the tests. Do i remove the chassis and poke around with the scope? I don't see any way to hook up a scope and adjust the horizontal at the same time any other way. Sorry for the questions. This is the first tube set I've had.
Old 07-30-2018, 10:33 PM
Weak CRTs typically get better the longer they are on in my experience.
It sounds like a component is drifting at warmup and messing up the H osc operation, or shifting the bias to the H output...Shifting CRT base bias could also cause that if the HV holds steady through the blackout.
First, verify that one of your scopes work. Most ones made in the last ~40 years have an internal square wave generator with a terminal on the front panel...Hook a probe to it and an input and check that you can make that square wave appear on the screen with a decent wave shape and amplitude that makes sense relative to the scale on screen, the voltage setting and multiplier of the probe.
If your scope is good there are a few ways to do the procedure. Some RCA sets have 2 cores in the H osc coil one accessible via the back or top of the chassis the other only available underneath the chassis...If there are two slugs you will probably need to adjust both. Assuming a transformer powered set you can pull the H output tube and adjust the osc with the chassis on the bench (on a series string reconnect only the heater leads of the tube using clip leads).
If you ever need to scope something with the chassis in the cabinet there are
options for that too...You can get tube socket savers/extenders with test points on them to probe test points on tube pins. You can also get alligator clip leads to bring test points out from under the chassis (and avoid putting your probes at risk of mechanical damage). If you can't get the scope close enough to the set for the probes to reach you can get BNC extender cables for the probe(s)...Make sure to get the right impedance cable (most scopes/instrumentation use 50-ohm impedance cables).
Old 07-31-2018, 01:56 PM
Sealtest,
Just one oscilloscope is usually enough.
What scopes do you have? Older scopes work somewhat different than newer ones. I can steer you in the right direction for "how to"s on them online. Many of the ones that come up in a search deal with very modern types.
Do you know if any of them work?
Do you have probes for them?
TVs are very complex in there operation, until PCs came out they were the most complex electronics in the home.
Getting the screen to "light up" is called getting a raster. That is about half way to getting a picture. Not to be confused with getting the heater in the CRT to light.
Old 07-31-2018, 02:02 PM
That's not exactly right. Some high frequency scopes do have a setting for the input that is 50 ohm, however the more typical scope input is 1 Megohm.
Using the 50 ohm input would load down the normal points a scope would measure. Normal scope probes use special low capacitance coax.
Old 07-31-2018, 02:11 PM
I
Usually you have to pull the chassis out to get to the points you want to measure. Basically you attach the scope probe to a point in the circuit. There are a few spots that are accessible without pulling the chassis, it depends on the chassis. They did make tube test adapters that allowed you to connect to the tube terminals without accessing the bottom of the tube sockets but those are hard to find now and expensive when you do find them. I don't like the phrase "poke around" when dealing with high voltage tube circuits.
Old 07-31-2018, 08:44 PM
irext's Avatar
irext irext is offline
The other thing to watch out for, all though not relevant in this case but worth mentioning, is when attempting to use a CRO on a live chassis set. The set under test must be connected to the mains via an isolating transformer otherwise bright blue flashes occur! ie path to earth via the CRO probe and CRO. Usually results in damage to the probe, the CRO input and the set under test. It's particularly spectacular in Aus as we have 240V mains.
Old 08-01-2018, 02:56 PM
Sometime either today or in the next day or so I am going to clear my bench and take the chassis into my shop and try all that you all mentioned. I really do appreciate the help with this. Tv repair is a big jump from vintage hifi restoration like I used to do.
As for oscilloscopes I have a Kenwood CS-4025 which is no good for this set since it only goes to 250v. The Tenima 72-720 goes to 600v so it should be best. Both are calibrated and tested.
I did not know about using an isolation transformer. Very good advice. I just got one out of a tv repair shop that needs testing (condition is poor).
Old 08-01-2018, 07:43 PM
Actually the Kenwood would be fine if you use a 10X probe. The DC voltage on a signal can be high in a TV but the AC voltage isn't usually that large on most points. Use the AC setting of the input to remove the DC. There are some point you should never try to measure, even with a meter, unless you have the special probes, the Horizontal Output plate and the HV rectifier terminals.
Old 08-01-2018, 08:39 PM
Makes sense. I might use both scopes just to compare the two.
But here is a new issue. I removed the tv chassis and took it into the shop. I have it connected to a isotap transformer all ready to go, but now the high voltage does not come on at all. I've been looking for loose connections and made sure the transformer is putting out the right amount of power but no luck. Does this chassis have to have the picture tube connected to complete some sort of circuit?
Old 08-01-2018, 09:20 PM
Tom9589 Tom9589 is offline
It's possible that the plug for the yoke has a jumper between two pins which breaks the B+ going to the sweep circuits.
