1971 RCA CTC-39 “The Calhoun”
I got this set from an estate sale March 22nd for $30 I think it was. I took this set to TUD1’s abode and the first thing we did was test the cathode ray bulb. The CRT test results were absolutely fantastic, the needles shot up to about .9 like a rocket, blue is slightly lower than red and green, but not enough to make any difference. The needles stayed up for nearly 15 seconds when the life test button was pressed. Checked the fly and there was almost no wax drippage, also the set has all it’s original tubes except for a replacement GE 12GN7 (or whatever it is). We turned the set on and we got sound and then a raster, that’s as far as we went testing the set. Me and TUD1 proceeded to take the chassis and CRT out to perform cataract surgery and that process went swimmingly. I got the set home and put a signal to it and it doesn’t look all bad except for the convergence is way off, and so is the vertical linearity, but I’ll get to that stuff real soon.
Your good times will bring me down |
Nice find!
Did you removed the chassie from it? What's the diagonal of the screen? |
Yes, I had to remove the chassis a few times for a few different reasons including removal of the cataract. The screen is 23”.
Nice TV. You should try to play old console games on it. LOL
I most certainly would...
Audiokarma |
Here it is as of now. Did some convergence but still a bit to go. Greyscale is on hold for now because the blue will not turn off when the screen control is fully counterclockwise.
There should be a brightness range, sub brightness, kinne bias, etc control hidden in the service controls...turn that down till blue at g2 goes dark at minimum, then you should be good to go on greyscale.
Thread Tools | |
Display Modes | |
