-   -   Flyback for an RCA 8-PT-7030 (http://www.videokarma.org/showthread.php?t=107037)
fsjonsey 04-02-2007 04:55 PM
I was attemting to repair one of the solder lugs on the flyback cage and my soldering iron practally vaporized one of the hairlike copper transformer leads. So, now i am in the need of another flyback. I was wondering if i could substitute a similar flyback transformer from another B/W set of a similar screen size, or a more modern one from a solid state tv. I really want to get this set working. I completely recapped the chassis, and then this happens. Ugh.
Phil Nelson 04-02-2007 11:22 PM
Is there no way to c-a-r-e-f-u-l-l-y dig out or peel back enough of the wire stub to solder on a new lead? I broke a hair-thin flyback lead on my Predicta while cleaning in that area. It was a big pain in the keister, but I was able to fix it.
Just an idea . . . replacement flybacks are not always easy to find.
fsjonsey 04-03-2007 12:19 AM
I've never seen a soldering iron do that before. It actually vaporized the wire, down to the point that it was down in the bobbin, under the paper and wax.
Einar72 04-05-2007 09:34 PM
Was there any leakage from the soldering iron? An un-grounded iron can be nearly at power-line "hot" voltage due to an internal short. Plenty of current available to make your flyback wire act like a flash-bulb! Of course, there would have to be a path to ground somehow, like a grounded bench-top or frame...
Eric H 04-05-2007 09:36 PM
I still need to dig out the spare chassis I have and see how it looks.
fsjonsey 04-07-2007 02:44 PM
Thanks. I appreciate all the help.
