-   -   Nice ion burn (http://www.videokarma.org/showthread.php?t=139990)
yagosaga 12-21-2007 05:24 AM
Nice ion burn
see
http://bs.cyty.com/menschen/e-etzold...Ionenfleck.jpg
Who has some more photos of ion burns on the screen?
- Eckhard
jpdylon 12-21-2007 10:19 AM
Yikes! :yikes:
That is scary. The phosphor looks almost completely gone!
yagosaga 12-21-2007 11:28 AM
Originally Posted by jpdylon (Post 1531250)
Yikes! :yikes:
It is not as bad as you think. This photo was enriched with contrast to make it more visible. I have created a Wikipedia article with an actual ion burn photo (with normal contrast):
http://de.wikipedia.org/wiki/Ionenfleck
But with moving images you don't see the ion burn after a while. See this photo from the same tv set:
http://bs.cyty.com/menschen/e-etzold...e/img/LV30.jpg
Who can make more photos from ion burns on the screen? I want to compare these to see whether they look similar or not.
- Eckhard
bgadow 12-21-2007 11:50 AM
I have a worn-out Zenith 10BP4 with obvious spotchiness of the phosphor. It isn't concentrated in the center like the one pictured, though. If not ion burn I'm not sure just what it is. It's stuffed way back in the attic but sometime I'll pull it out and get a picture.
mattdavala 12-21-2007 01:46 PM
I've seen a couple CRT's with phosphor that flaked off , not related to Ion burns. I am not sure if that is the spotchiness you are refering to. I have a Dumont 15AP4 that is missing a speck.
Matt Davala
nasadowsk 12-21-2007 08:23 PM
I had a Zenith with a spot burnt right through in the center, where the turn-off dot generally is.
I had a rotted tube in a tek scope once that I pinned the brightness on and XY drew by burning off the phosphor. I wasn't the first one to try that 'experiment' on it, either. Tek sold a kit to internally limit the brightness, for just such a reason...
I wonder where the stuff goes, after that, though?
