admiral 19A11 recapping
I replaced most of the capacitors and 2 bad tubes in my Admiral 19A11. Sadly still no raster or audio. Tubes do light up. I still have 9 more non-electrolytic caps i haven't replaced mostly .005 @ 400v. I was hoping to get some sign of life at this point.
I'd check and see if you have B+ at pin 7 of the 6AS5 (210v) and on pin of the 6SQ7 (75v). If so you got a good chance that the audio amp is working.
Terry |
| All times are GMT -5. The time now is 08:30 PM. |
