-   -   Beltron question... (http://www.videokarma.org/showthread.php?t=146841)
John Marinello 01-31-2008 09:49 PM
Beltron question...
What's the difference between the 8080-A, and the 2972-E?
They look very similar:
http://cgi.ebay.com/ws/eBayISAPI.dll....cWAT.m240.lVI
bbonds73 03-21-2008 12:00 PM
8080
We have the 8080 and and we don't know the wiring for the universal adapter. We also don't know how to post a new thread on this. Perhaps we can help each other?
Thanks!
kbmuri 03-21-2008 09:25 PM
Mine is the 2972-E. It works magnificently. Let me know if I can help with any details.
bbonds73 03-22-2008 12:06 PM
I have the model 8080a and the universal adpt leads just have the clips on the ends but they are not marked which is heater,K etc do you know the pin out of the universal adpt??
Big Dave 03-22-2008 06:59 PM
The Beltron pinout:
Pin 1.: No connection
Pin 2.: Heater
Pin 3.:G1 Blue
Pin 4.: G1 Green (black and white)
Pin 5.: G1 Red
Pin 6.: No connection
Pin 7.: Heater
Pin 8.: Cathode
andy 03-23-2008 11:57 AM
Big Dave 03-23-2008 12:26 PM
The Pinout I Listed Is What Was Shown In My Instruction Book!!!
andy 03-23-2008 12:56 PM
John Marinello 03-23-2008 09:59 PM
Originally Posted by andy (Post 1738646)
Maybe it's a typo. I can't imagine that it would work with the cathode and G1 pins swapped. Can anyone verify the pinout by looking at an actual adapter socket (using the CRT's pinout as a reference)?
Big Dave and Andy are both right! Some testers made the grids common, but Beltron chose to make the cathodes common, and they all connect to pin 8. The CRTs with a single G1 pin use a different adapter.
andy 03-24-2008 12:29 AM
jeyurkon 12-04-2008 09:24 AM
Originally Posted by andy (Post 1738543)
Are you sure about that? I think you have the cathode and G1 pins swapped (pin 8 is the common G1, and pins 3,4,and 5 are the cathodes). This is how my home made adapter is wired and it works. Your pinout would make it impossible to use with modern CRTs that have a single G1 pin.
My Beltron has an octal to a 9 pin adapter cable (labeled adapter A). The 9 pin connector is made by AMP. Does anyone know the exact model of connector that will fit it? I want to make my own adapter sockets.
I believe it's AMP (Tyco) 1-640511-0 using pins 640545-1.
John Y.
andy 12-04-2008 09:19 PM
