Juliette Super 7 Micro
3 Attachment(s)
Found one of these digging around at GW today.
I haven’t tried to power it up yet. Looks like someone had messed with it before. So I will check to make sure everything is connected properly and replace the lytic caps before attempting to turn it on. Maybe someone here knows where I can get an on-off \ volume knob to replace the one that’s missing. I think this one originally came with a leather (or leatherette) case. |
That's a cutie.
If it was mine I would try it without changing the caps because I have stuff older than that with original electrolytics that work fine. However, it is certainly best to change them.
I wonder if some child turned those coil slugs as I had done once to see what they do. Looks like the white paint seal was broken on a couple. |
Someone was definitely screwing with it.
It will most likely need an alignment once its up and running. |
| All times are GMT -5. The time now is 08:36 PM. |
