-   -   1950's RCA Monitor (http://www.videokarma.org/showthread.php?t=197816)
Eric H 12-11-2008 01:48 PM
1950's RCA Monitor
http://cgi.ebay.com/1950s-RCA-televi...3A1|240%3A1318
cbenham 12-12-2008 12:23 AM
Just FYI, this monitor has no built in B+ power supply. There is a filament supply but that huge 10 pin Jones plug near the bottom is where the BIG power supply plugs in. There are two versions of the power supply, the earlier is all tube and a later version solid state.
radotvguy 12-12-2008 06:05 AM
looks like a nice winter project for someone
Phil Nelson 12-12-2008 02:53 PM
Interesting. Knowing nothing about broadcasting equipment . . . what would be displayed on the little oscilloscope screen? If something basic like signal strength, you'd think a simple meter would do.
Just curious.
Sandy G 12-12-2008 03:01 PM
SOMEBODY wants th' damthing...Nearly 6 days out & 40 bux already...For something that is old, prolly won't work, & rather obscure, thats pretty good...
radio63 12-12-2008 05:41 PM
The oscilloscope screen is a waveform monitor. It displays the video signal as a trace, for adjustment of video levels, pedestal, and observation of sync signals. Waveform monitors are still in use in television stations to this day. RCA sold this unit as a "Master Monitor", to incude the video monitor and waveform in one unit.
Gilbert
Eric H 12-12-2008 08:17 PM
You could put some nice tropical fish in the large area and some gold fish in the small area. :D
dtuomi 12-12-2008 08:35 PM
I'd love to chase after it, but it would never survive shipping to California.
David
grimer 12-12-2008 11:44 PM
bgadow 12-13-2008 09:20 PM
This is along the lines of the monitors in Julian's remote TV van, as outlined in another thread. I noticed those scopes there, too, and found it interesting.
cbenham 12-14-2008 01:10 AM
Originally Posted by grimer (Post 2317185)
A quite tempting item indeed..........Does this model require external sync ?
Yes, and even more: H and V Drive, Composite Blanking as well as that huge [not included] power supply I mentioned above. The various signals would come from a broadcast sync generator. Such generators are found on eBay from time to time, like Tektronix 146 through 149 types. The original from RCA had almost 100 tubes and filled a 6 ft high equipment rack.
dtuomi 12-14-2008 04:11 PM
Really? Were these signals inputted through the power supply multipin connector? Because the picture in the auction of this monitor only shows two UHF style connectors for video on the back, which I presume are for video in and loop out.
David
julianburke 12-14-2008 07:14 PM
Waveform Monitor
It originally had a green overlay over the scope tube. Either it went bad or someone didn't like it.
