-   Antique Radio (http://www.videokarma.org/forumdisplay.php?f=16)
-   -   Stereo speaker input puzzler - Zenith C845 (http://www.videokarma.org/showthread.php?t=220125)
Jeffhs 03-27-2009 07:20 PM
My Zenith C845 radio has a terminal strip on the rear of the chassis, near the phono input and radio/phono selector, marked "Stereo Sp'k's Input". I tried hooking up a speaker to these terminals but got nothing. (The radio's internal speakers work as they should.) However, I am wondering what the function of this "stereo" input would be on a radio that obviously is not designed to receive stereo FM broadcasts in stereo, as there is no MPX decoder or second amplifier. Hmmm. :scratch2:
Thanks in advance for any info on this, as I am downright puzzled as to why a monophonic AM/FM radio such as the C845 would have an external speaker input. The only thing I can think of is that Zenith may have marketed a stereo retrofit kit for these radios that would have allowed them to receive stereo FM; however, I don't see any place on the tuning scales or on the cabinet front where a stereo indicator would have been mounted, and the band switch does not have a "stereo FM" position.
jeffsod 03-27-2009 09:36 PM
Does the radio have a phone setting? It might have been able to replicate stereo while playing albums.
Jeffhs 03-28-2009 12:36 PM
I'm not sure what you mean by "phone" setting, unless you're referring to the "phono(graph)" position of the radio-phono selector switch near the RCA phono input jack on the rear apron of the chassis.
KentTeffeteller 03-28-2009 06:05 PM
jeffhs,
Zenith marketed a companion speaker and FM MPX adapter for your radio. That plug was for that device. The device was called a Stereo Companion.
Jeffhs 03-28-2009 11:39 PM
1 Attachment(s)
Originally Posted by KentTeffeteller (Post 2624509)
jeffhs,
Thanks for the info.
I'm not sure we're on the same page. My C-845 has no plugs on the rear of the chassis except the RCA phono input jack and the AC interlock. What I am referring to (the external speaker terminal strip) is shown in the picture I've attached.
The adapter you mention doesn't ring a bell. The one Zenith FM radio that I can remember having an external stereo FM adapter was their model MH-902 from the 1960s, known as the Zenith "Stereo Multiplexer", which worked with the main receiver to provide stereo FM reception. I was not aware (until now) of aftermarket stereo adapters being available for any of Zenith's other high-end table sets, so it was news to me when you mentioned the "Stereo Companion". That adapter must have been introduced at the same time as the C/H-845 series but before the MJ-1035, the latter being factory-equipped for stereo FM.
jeffsod 03-29-2009 08:14 AM
Sorry I meant to say Phono. I know some radios were stereo in phono but didn't have stereo receiving capabilities.
