-   -   Admiral P17E31 scored (http://www.videokarma.org/showthread.php?t=249661)
bandersen 12-22-2010 08:55 PM
Thanks to WISCOJIM I made a nice little haul today including a 1958 Admiral P17E31 portable. It has a metal cabinet with gray hammertone finish. Seems to be in good shape - just a little dirty.
Not the type of set I usually go for, but it was free and is slowly growing on me :yes:
http://farm6.static.flickr.com/5050/...58be952a_z.jpg http://farm6.static.flickr.com/5089/...e94a3154_z.jpg http://farm6.static.flickr.com/5122/...818f2caa_z.jpg http://farm6.static.flickr.com/5127/...a489a37b_z.jpg
I also picked up a partial Riders set. I think volumes 3-28 were there, but I only took some - just don't have the room for everything.
Maybe the schematic for this set is in one of them ?
http://farm6.static.flickr.com/5285/...043d055a_z.jpg
Also got a couple video cameras and a bunch of random tubes.
http://farm6.static.flickr.com/5004/...eb591e19_z.jpg
http://farm6.static.flickr.com/5164/...91474419_z.jpg
jeyurkon 12-22-2010 09:12 PM
Nice haul!
Boobtubeman 12-22-2010 11:24 PM
DANG!!! I just tossed out the monitor that sits atop that sony camera... and i know it worked... Had it sittin here for years...
Wish this score was a few weeks sooner..
SR
bandersen 12-23-2010 11:42 AM
SR
Oh well. Do you think the camera will work with a B&W TV ?
Boobtubeman 12-23-2010 03:23 PM
It sure will. i had one back in the 80s and i used it on a tv. it will require a LINE IN to feed the video from it.. it should operate at 12 volts..
SR
bandersen 12-23-2010 09:17 PM
I found this set in one of the Riders (#24) I just hauled home :)
I can't believe it doesn't have a transformer. It must weight 50+ lbs!
http://farm6.static.flickr.com/5089/...61b1bc17_b.jpg
bandersen 01-09-2011 03:44 PM
I popped the back off this set and took a look inside. It appears to be in pretty good shape - nothing obviously blown.
http://farm6.static.flickr.com/5245/...80bbf0f2_b.jpg
http://farm6.static.flickr.com/5284/...0ae4f331_z.jpg http://farm6.static.flickr.com/5088/...5c253f21_z.jpg
Horizontal output tube looks dead.
http://farm6.static.flickr.com/5287/...4c73f967_z.jpg
This could be why :tears: I see a few cracks in the old coating so I suspect this was a attempt to stop arcing.
I haven't tested it yet. Hopefully, it's still good under all that tape.
http://farm6.static.flickr.com/5010/...3f0320b4_z.jpg
Now to test the CRT. I would have used my Sencore CR70, but I'm missing the #4 adapter :(
So I had to drag out my old B&K 440. The emissions came right up into the good range. The life test stinks though - even after an hour of running. Oh well, I'm sure it's good enough to produce a picture.
http://farm6.static.flickr.com/5170/...533bc73d_z.jpg http://farm6.static.flickr.com/5204/...45c4fbfc_z.jpg
7"estatdef 01-09-2011 04:18 PM
Bob
I had one of those set about 20yrs ago. Good playing little set. A little cramped to work on.
Terry
bandersen 01-09-2011 04:22 PM
Any suggestions for taking it apart ? I've never worked on a portable like this.
kvflyer 01-09-2011 06:35 PM
Originally Posted by bandersen (Post 2991469)
I popped the back off this set ...
So I had to drag out my old B&K 440. ...
Bob,
You can use the universal adapter with the Sencore CR70 if you are missing the #4. Unfortunately, most of what I test has to use the universal. Really!!
Sandy G 01-09-2011 06:42 PM
Kewl set !
Tubejunke 01-09-2011 06:53 PM
If the chassis looked like that before any cleaning or blowing out, and with the number of stock tubes that I see, I would say that the set has low hours on it! Is the CRT an Admiral?
Eric H 01-09-2011 07:04 PM
The chassis on these portables usually unbolt then tip and remove out the back, unplugging the anode can be a challenge sometimes.
I never pay attention to the life test, if the tube goes up to good with little warm up then it's fine.
The Fly looks a little worrisome though, shouldn't be too hard to find one though.
Boobtubeman 01-09-2011 07:40 PM
When i rebuilt my motorolla i actually removed the CRT first with the yoke connected. It had a plug...
then removed the anode to the CRT.. It made removing the chassis alot easier...
SR
bandersen 01-09-2011 10:48 PM
Thanks for all the tips!
Originally Posted by kvflyer (Post 2991490)
Bob,
OK, I thought that would be the case. I guess it's just a matter of figuring out which CRT pins are filament, grid and cathode.
That's what I was thinking too. Other than the flyback, it's very clean inside. Yes, it's an Admiral CRT and very likely the original.
BTW I finished sorting through all those loose tubes. No hidden treasures, but I did find a bunch of good 5U4s and 6SN7s.
http://farm6.static.flickr.com/5124/...86084dcb_z.jpg
