Pix tube extension for 15gp22
anybody have a extension for the 15gp22 that I can buy, borrow
or use to find my missing raster? thanks in advance, Neil K8RX |
Huh, say what?
Extension cord
Clarification-----picture tube extension cord
Thought your set worked already? Bob G has one, but he's very distracted by family issues right now.
I have one but it's only 1 foot long. I that enough length? It's fits the 21" tube. Not sure if they have the same pin-outs and base
I believe that the 15Gs had a different socket with more pins.
The 15GP22 has a 20-pin base. The nearest I know of is a man (named Terry if I remember right) who found either just the part number or an actual source/quantity of the correct 20-pin sockets, that was still sold/made for photomultiplier tubes in the 1970s, I think. It was something like a Cinch-Jones PM20 or 20PM socket. I would like to have one of them so I can make a CT-100 (CTC-2) adapter for my test jig. I have not heard of any sources for the plug, though.
1 Attachment(s)
You can use RadioShack jumpers & nails that fit socket
The nails that fit these sockets are 8-Penny Finishing Nails |
I made one up at one time, using the base off a military electrostatic tube of some sort, and a socket from a fire-damaged CT-100 chassis. I remember having a problem with the convergence anode arcing though, and I wasn't able to solve it.
Charles |
http://www.google.com/search?q=PMT+S...rlz=1I7DKUS_en The $64K question is whether anyone actually stocks 'em. Phil Nelson |
A company called OE Technology www.oetech.com used to have some 20 pin PMT sockets, but my link to their website no longer works, so maybe they are gone....?
Phil, I got Terry's name and the other information from the archive of Pete's Web site.
I took your Google link and ran with it, and got at least two part numbers for that socket: Photonis FE-1120 and Hamamatsu E678-20B. Photonis makes a photomultiplier tube, the XP2262B, that appears to use a base similar to the one on the 15GP22. That base is in fact the number you found, JEDEC B20-102. If that company will sell both the base and the socket, Neil could make the extension he needs (using HV wire on pin 13 and some kind of high-voltage silicon to seal it perhaps). |
1 Attachment(s)
This is the back story re the connectors: Terry Wise acquired a number of factory-packaged Cinch 20-pin sockets that are identical to some CT-100 production sockets. He was kind enough to ship me one, which I used to make a 15GP22 Beltron-adapter, and he contributed the rest to the ETF. I don't know if any are still available (if so, a contribution to the ETF would of course be appropriate); contact Steve McVoy.
Also, Neil I have an untested-by-me multi-foot-long 15GP22 extension cord that was made about 45-years-ago. You can borrow it if you like, but you should ring it out first before using. Historic Data: the connectors on this particular cable actually came from the technical department of CBS at 485 Madison in Manhattan. Photo is it hanging on the wall of my tiny workshop. Pete |
Wow. What an interesting and convoluted trail your 15G connector will have followed if Neil should borrow it.
Thanks for the notes, Pete. Just now, I realized that if I make a test jig adapter, I will need a plug (substitute CRT end connector), not a socket. Oops... Maybe I can get lucky with this company Photonis.
| All times are GMT -5. The time now is 11:59 PM. |
