Motorola 9VT1 Speaker
Can anyone recommend a good replacement for the speaker in this model? Mine is damaged and I am having trouble figuring out which size I need. The cone measures a little over 5 inches and the mounting holes are about 6 inches from opposite corners. Do I need a speaker labeled as a 5 inch? Just how do I match this up? I just bought a 6 inch speaker and it is too big.
1 Attachment(s)
See if you can match it to one of the standard sizes at the end of this pdf file from Quam. This isn't every size ever made, but it's got a lot of them.
It's probably a 5 1/4" "pincushion" frame. Rat Shack used to carry these. You might want to see if yours still has some kicking around.
| All times are GMT -5. The time now is 11:57 AM. |
