Are these just holddowns
1 Attachment(s)
I took all the press-in modules out for a cleaning and cleaned the contacts. On each module were two blue plastic tubes on unused pins. I looked them over and they serve no electrical function, so I'm assuming they were used to keep pressure on the board to stay seated.
Do I need these? The boards seem to fit snuggly on the pins and I don't see them on my other CC2 (no problems with the boards coming loose). You can see them in the attached picture on the vertical and horizontal boards. Thanks |
As far as I know...those are just hold down sleeves. Most likely from shipping.
I always try to put them back for aesthetics, but I bet they were intended to insulate higher B+ voltages in case of wandering fingers during setup adjustments, etc.
Charles |
Just hold downs, do as you with with them.
73 Zeno:smoke: |
They are gone. There is no voltage on any of the pins they covered. Since I don't plan on operating the TV upside down or shaking it, I can do with out them.
Thanks! |
| All times are GMT -5. The time now is 11:18 AM. |
