-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   This has to be a fixable issue (http://www.videokarma.org/showthread.php?t=258869)
TinCanAlley 07-20-2013 06:49 PM
1 Attachment(s)
Earlier I posted a pick with red and blue ghosting around white lines. I've noticed it also is showing up around on-screen displays and in some areas of black and white images.
I'm hoping this is something fixable. On my '77 CC2 I do notice it very slightly around on-screen info and on crosshatch patterns, but nowhere near as bad as the Avanti. I'm hoping it's a capacitor or something as it's pretty annoying and embarrassing when showing off the set. It's really noticeable.
I'm attaching a pic of the onscreen menu and this link with the previous pic: http://videokarma.org/showthread.php?t=258838
old_tv_nut 07-24-2013 08:52 PM
It's just the usual crosstalk for a set without a comb filter. People forget what this looked like since they got used to digital component video. It can be reduced if the input video has the luminance frequency response rolled off, which your source of lettering obviously doesn't.
Eric H 07-24-2013 09:12 PM
Some of that looks like it could be a bit of blue misconvergence.
As I recall you had an issue with the blue on the right side of the screen.
Have you recapped the convergence board?
zeno 07-24-2013 09:26 PM
Normal. Back then there was nothing that would give the
kind of signal that the OSD does so it wasnt a big issue.
Note the rest of the pix is good. When Zenith started using
comb filters about 7 yrs later ( M line IIRC) & you side
by sided them the difference was startling. I think about
75% of the customers spent the extra $50 to get it.
All but eliminated things like you see but also made a big
difference in resolution. Individual hairs could be seen instead
of a blur at best. You may not see it much on other older sets,
thats because they arent as good as yours.
A few things do improve with time........
73 Zeno:smoke:
TinCanAlley 07-24-2013 11:26 PM
I found it's more a product of the RF modulator. I was feeding it an S-Video from the DVD player, so I switched it to the composite and it was greatly reduced. It's at a level I can live with.
TinCanAlley 07-24-2013 11:31 PM
I didn't find any caps on the convergence board. Just pots and coils and non-electrolytic caps and a couple resistors. I will be replacing all the electrolytic caps on Friday on the bottom side of the chassis and the modules. I also have a new/updated subcarrier regenerator coming (I like it because it is self-shielded, so the pots are visible for adjustments.
After all the caps are replaced, I'll see what needs adjusting again and then do the convergence.
ChrisW6ATV 07-25-2013 01:54 PM
73 Zeno:smoke:
Excellent descriptions of the issue!
In the era between the introduction of color TV (1954) and the widespread availability of comb filters (1980s), high resolution was just not available or expected in broadcast TV reception and signals, so you rarely if ever saw any content with detail like those characters. (This is one reason why consumer VCR formats have only 240 lines of resolution; that was about all a color TV set could display throughout that era.) Put a 1990s or newer video game or similar device on a 1970s TV, and this is what you get. It actually looks better than a lot of older color displays I have seen when showing high-resolution signals.
