crt brightners ?
I need a brightner for a 14BP4, I've never had to use one before but,
this crt is really on its last legs, and I need to do something till I can get a replacement crt. The problem is which model of brightner do I use ?. I see several on the bay that have the correct base, but how do I know it will work on my crt ???. Any info would be appreciated and, if anyone has a 14BP4 to sell, then I wouldn't need the brightner !. Thanks Bob R. |
Bob,
You may want to start with the question of whether it is a parallel string or series string for the filaments. That should get you started. I think that there were even isolation transformer types for those situations where there was an H-K short... |
It is for a parallel filament tv, Thanks
bob |
I used them on the real "sickies". :sigh: |
:screwy:I've seen brighteners "bootstrapped", ie., a brightener plugged into a brightener, then into the CRT.
Ok, so most brightners just increase filament voltage, with
that in mind I made a voltage doubler, then ajusted a series resistance till I ended up with 8 vdc across the filiment of the crt. Now I can see the screen with the room lights on !, a vast improvment,:banana: for as long as the decrepit 14bp4 lasts. Anyone got a crt for sale ????, please let me know. Bob R. |
I have one that has a switch for series and parallel. That is my keeper, but I am fairly certain that I have some others. Sounds like your home made job did the trick for now. Great thinking!
i took a brightener that a set needed and put a resistor on it , the thing sent 10 volts to the crt , after the resistor 7 volts and that little extra is just enough to make a bright picture and better contrast , so thats an idea for others , this way you aren't constantly overdriving it and get a usefull picture out of it , if its too far gone then yes it will need more voltage.
i have seen rare cases where using a brightner for a hour or so after it is removed the picture is better then it was before and stays that way except for a slow time when the set is turned on but rarely does it stay that way. mike |
maybe someone in your town has a Beltron, a machine that can fix up CRT cathodes. I used one on a weak CRT in a B&W RCA TV I have, and it made the CRT work without a brightener.
| All times are GMT -5. The time now is 03:15 PM. |
