-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   What are these holes in Zenith Channel #s (http://www.videokarma.org/showthread.php?t=259567)
TinCanAlley 09-21-2013 04:48 PM
1 Attachment(s)
The channel number inserts in my Avanti are either damaged, missing or numbers I don't like/use. I managed to find an unused sheet of them, but was wondering why the 2 - 13 inserts have a hole in them while all the other do not. The numbers in that range that are currently in my set also have a hole.
Anyone know the reason? Seems a bit odd to me.
N2IXK 09-21-2013 04:56 PM
Not familiar with the specifics of the set, but since 2-13 are VHF channels, and 14-83 are UHF, the hole may be used to switch between UHF and VHF tuning range.
TinCanAlley 09-21-2013 05:02 PM
I think that's it. I just looked and realized that there is no way to switch between VHF and UHF when setting up the channels, so the insert must do it for you.
