-   -   bakelite admiral craigslist find (http://www.videokarma.org/showthread.php?t=259858)
annuvin 10-25-2013 06:02 PM
1 Attachment(s)
seller wants $40 and i'm itching for my next project, should I pull the trigger on this admiral? I'm told it's the largest bakelite tv ever made.
Electronic M 10-25-2013 06:50 PM
There were larger screen versions that were bigger, but they are also less common.
If the case ain't cracked you can't go wrong @ 40$ IMHO.
Sandy G 10-25-2013 06:53 PM
Yeah, if the Bakelite's good, that's a pretty good price... Only other concern would be if the CRT's OK..IIRC, those Bad Boys have 2 Chassis, too..
oldtvsandtoy 10-25-2013 07:04 PM
Yes Buy it. Bad tube or not well worth the price. Bring it to me and I would give you 2x the price.:yes:
bandersen 10-25-2013 08:43 PM
I'd definitely check it out. If the cabinet is damage and CRT OK, it's a good deal. However, I'm a little wary because all the knobs and channel plate are missing and coudl be hard to replace. Also the grille cloth looks torn at the bottom. Good luck!
Here's what the knobs look like.
http://farm3.staticflickr.com/2786/4...313e1bcae1.jpg
annuvin 10-25-2013 08:58 PM
1 Attachment(s)
looks like it could be a money pit to restore, I bet i'd never find a complete set of knobs.
bandersen 10-25-2013 09:54 PM
I wouldn't go that far. I could certainly help you out with some of the knobs :yes:
Kevin Kuehn 10-25-2013 10:49 PM
Heck if the Bakelite is not cracked up the cabinet should be worth the $40.
Bill Cahill 10-26-2013 08:57 PM
I'd definately buy it. Knobs are a little hard to get, but, not terribly.
I even had to get the channels escutcheon, but, managed to find one for mine...................
bars&tone 10-26-2013 11:08 PM
I was getting ready to say the same thing.
kramden66 10-27-2013 08:24 PM
get it , regardless worth it
Electronic M 10-28-2013 04:22 PM
On a set like that the CRT and cabinet alone are probably worth around 200$, start adding stuff like tubes to that and that set starts to have a good amount of value as is. I've seen that model in restored shape for sale for well north of 400$ so even if you toss 50$ of knobs in it and a c-note for a CRT you are still not too deep in it.
If that set were offered to me at that price and if the bakelite looked solid I'd buy it regardless of the condition of the rest.
tvtimeisfun 10-28-2013 08:28 PM
Buy that tv do not pass this set up.....Timothy
Tubejunke 10-29-2013 12:18 AM
On both the buying and the selling end I wish that we could consider the worth of the tubes. If you are letting go of a set with a good set of tubes and you have new capacitors or whatnot in it, most sets would command more than they typically do. I know that sets like this Admiral fall more into the true "collectable" category so I'm just generalizing. So generally you might get $50 for some average 50s set for instance. It really doesn't cover the tubes, much less the C.R.T.
Recently, due to space and a woman I have had to dump sets at local thrift stores and as much as I hate to do it I remove the tubes. Who wouldn't unless they were completely getting out of vintage electronics? I hate to do it because I feel that it lessens the potential of another person successfully getting the set going, thus increasing dumpster potential, or even worse fish tanking! :thumbsdn:
Bottom line I guess is we have a hobby, and like restoring automobiles or any other (unless you collect gold and silver) hobby, it's more about the love than the money. Inversely you will get your heart broke. :tears:
