-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   Console TV (http://www.videokarma.org/showthread.php?t=260247)
Console User 12-12-2013 05:28 PM
Console TV
Can someone tell me why I recently had to change my Tv from Channel 3 to Channel 4 with the use of my Converter Box to avoid certain commercials and bold black lettering from shaking on the picture? This is a 1986 RCA TV.
I had always used the Channel 3 setting before and had no problem until before Thanksgiving.
Could it be something with the Tuner on Channel 3 or just a glitch with the conversion on the box?
Thanks.
lnx64 12-12-2013 05:29 PM
Fine tune adjustment. ;)
Sometimes it just needs to be re-adjusted or is bumped.
Console User 12-12-2013 05:55 PM
How and where would you make the adjustment on the inside of the cabinet?
Thanks.
TVTim 12-12-2013 07:31 PM
If it is a rotary tuner, it may be dirty on the channel three contacts. Four is probably cleaner and therefore a better picture.
lnx64 12-12-2013 07:37 PM
Thanks.
Well for one, I wouldn't think it's done inside the TV, usually on the tuner outside.
What's the model? Without the model this is a guess.. On my TV there's an inner knob on the main knob, and when pushed in and rotated, it fine tunes.
