-   Vintage TV & Radio Tech Forum (http://www.videokarma.org/forumdisplay.php?f=170)
-   -   Capacitor/resistor recommendations? (http://www.videokarma.org/showthread.php?t=262150)
Jon A. 07-12-2014 09:23 PM
There are so many types that I could easily end up buying crap. I've been perusing the Digi-Key site as I don't think Mouser has any through-hole resistors, that or I did something wrong. I need to know not just what brands to use but what composition/tolerance/etc.
Thanks
bandersen 07-12-2014 10:59 PM
Mouser has over 66,000 through hole resistors :) http://www.mouser.com/Passive-Compon...ors/_/N-7h7z5/
I like Vishay 2W metal film resistors. They are about the same size as the old 1/2 watters and are a nice deep red color rather than bright blue.
http://www.mouser.com/catalog/catalogusd/646/817.pdf
Here's a photo of some 3, 2 and 1 watt in the center
https://farm3.staticflickr.com/2892/...8d131389_z.jpg
Jon A. 07-13-2014 10:49 AM
What are the blue ones made of? I know that I shouldn't exceed the rated resistor wattage on SS sets because resistors can act as a fuse and further damage could be done if a higher wattage is used and something else is amiss.
bandersen 07-13-2014 01:10 PM
Oh, I assumed you were restoring tube sets. Smaller ones are metal film. Bigger ones metal oxide.
Jon A. 07-13-2014 02:22 PM
Right now I'm gathering stuff to fix a CTC88 with a well-known vertical problem. Very limited options with transistors so no problem there. Set seems near mint otherwise and very clean inside. Selecting component brands is my biggest hurdle, so thanks. Still need advice on caps though; I'm sure I heard someone else say Panasonic or Nichicon but I would need to confirm that.
powerking 07-13-2014 02:43 PM
I would avoid any/all no-name cheap as dirt Chinese branded caps that have been flooding the market. Stick with U.S. or Japanese brands like:
CDE (Cornell Dubilier)
IEC (Illinois Capacitor)
Sprague
Vishay
Panasonic
Nippon Chemicon
Nichicon
Xicon
Kemet
Rubycon
When replacing electrolytics, go for low ESR and high temp rating (like 125 deg C) for the best possible life expectancy.
Tom (PK).
bandersen 07-13-2014 02:54 PM
Agreed and I'll add Rubycon to that capacitor list.
NoPegs 07-13-2014 03:07 PM
I always forget about Rubycon for some reason. They really do make a quality capacitor for a fair price.
Jon A. 07-13-2014 03:21 PM
Oh yeah, that's exactly what I'm trying to do.
