-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   Sony 5-303W (http://www.videokarma.org/showthread.php?t=263603)
Gregb 02-14-2015 04:28 PM
Sony 5-303W
Hi:
I picked up a nice little Sony 5-303W with the case, cords and operating instructions. I have changed out the all of the electrolytic caps and it now works really good except for one little problem, I cant centre it on the horizontal. Its about half an inch, which is a lot on this little crt, to the right of centre and if I try to adjust it I get these strange looking bars across the top and if I keep going it loses lock. Other than that the picture and sound are perfect. Any ideas or does anyone have any service data on this set?
Thanks
Gregb
jr_tech 02-14-2015 05:11 PM
IIRC, there are a couple of rings at the rear of the yoke that are rotated to position the raster.
Edit add: Rotate the two rings *together* to move the raster up/down/left/right... Rotate one ring *relative* to the other to change the amount of position shift that is obtained when rotating both together.
Gregb 02-14-2015 06:07 PM
I will have a look, Thanks jr
Gregb
