-   Vintage TV & Radio Tech Forum (http://www.videokarma.org/forumdisplay.php?f=170)
-   -   What is the rating of this resistor? (http://www.videokarma.org/showthread.php?t=264129)
TheShanMan 04-28-2015 07:17 PM
1 Attachment(s)
I've got a blown 47k resistor but I'm not sure what the wattage rating is (or should be). The schematics don't specify. Can anyone tell me? It's 3.7mm in diameter.
http://www.videokarma.org/attachment...1&d=1430266362
Eric H 04-28-2015 07:47 PM
It's probably a 1/2 watt, most of them are in an old TV or radio.
The one next to it looks like a 2 watt.
TheShanMan 04-28-2015 08:12 PM
Thank you!
dieseljeep 05-13-2015 10:13 AM
If you compare the half watters with the burnt in half one, it seems to be a 1 watt resistor. Unless they consider the smallest resistors to be a quarter watt. I would use a 1 watt. First, you have to find the reason why it burned up. :yes:
TheShanMan 05-13-2015 10:33 AM
I did buy extras specifically for that reason, but so far so good. The radio is working great. The replacement seems just a tad smaller, but not small enough to make me question it. Next time I order parts I may reconsider the wattage though! Oh, and to be clear, this radio hadn't been recapped so the blown resistor could've been due to out of spec caps.
