wire resistor
1 Attachment(s)
Due to age of these 60 yrs do you replace these wire resistors? One is a 4800 ohm the other is a 2600 ohm. One still reads as rated on Sams the other is a little off but within tolerance. I was thinking they would be hard to find if they needed replacement.
As long as they're not open and are within tolerance, I would leave them alone for the time being.
Others' opinions may vary. |
I have never seen a wire wound drift in value,
only opened. Sometimes the shell falls apart & IMHO should be changed even if OK. Finding them should be no problem. Keep in mind many sets use a "fusable " resistor in the power supply usually 5.6 ohms 5 watt & you need to use the right thing there. 73 Zeno:smoke: |
Thanks for the opinions
| All times are GMT -5. The time now is 06:17 AM. |
