-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   1973 RCA portable B/W remote set? Hm.... (http://www.videokarma.org/showthread.php?t=264705)
Kamakiri 07-12-2015 09:42 AM
2 Attachment(s)
I never knew that any company made a remote black and white set as late as 1973....wow.
Picked up these two sets from two different places over the last month. I thought they were identical until I saw the "REMOTE CONTROL" written on the handle of the one on the left.
Not often that you see the year of production on a set tag, too :)
zeno 07-12-2015 01:15 PM
Zenith still had a 19" B&W tube SC sets up to D-line IIRC. Sold a
few of em. I thinks I saw one on E-bay last week.
Are those 16" ??
73 Zeno:smoke:
zeno 07-12-2015 02:31 PM
http://www.ebay.com/itm/Vintage-Zeni...item4d34fc7e8c
Not sure if this is a dura module or tube set. Pretty sure its
tubes. Pre UHF ease of tuning mandate. ( d-line or earlier).
73 Zeno:smoke:
rca2000 07-12-2015 03:32 PM
That one with the AR158Wr --is a KCS-168XE. Sams 1326-3. Pretty sure it is ALL tubes, hot, vertical chassis. Probably with the 22JR6 H-out, 17CT3 damper. MUCH older design that 1973...a "carry over"...
rca2000 07-12-2015 03:33 PM
73 Zeno:smoke:
Not SURE...but likely a 4-tuber..like the 12CB12
chassis.
zeno 07-12-2015 06:26 PM
chassis.
Not the hybrid, only used in 12" & 16" sets.
Lack of "solid state" label, back style & use of 1-100 ears point
me tward all tube chassis. Hybrids used the 1-127 that had an
offset screw. ( also CC2's used them) Antenna block looks like the same
plastic one used on hybrids & latter B&W sets.
73 Zeno:smoke:
dieseljeep 07-14-2015 10:10 AM
IIRC, the remote was only a two function, volume up-down and channel, one direction. Electronic ultra sonic transmitter.
Adam 07-14-2015 10:42 AM
I used to have a Zenith just like that one on ebay with the SC100. It had a tube chassis. I think it was a 71, making this 73 RCA the latest model b/w remote set I've seen. Remote b/w sets from 67 and newer seem to be very rare.
Jon A. 07-14-2015 11:40 PM
The volume rocker controls power as well. I have one of those with white end caps, probably for the ultra-modern XL-100 someone posted here a while back.
Could be one of these clickers as well:
http://www.ebay.com/itm/321624546474
dieseljeep 07-20-2015 10:23 AM
The Ebay remote, "Used and some wear"! More like used and abused and beat to h*ll. :sigh:
