-   Antique Radio (http://www.videokarma.org/forumdisplay.php?f=16)
-   -   New Project: GE F-80 (http://www.videokarma.org/showthread.php?t=264947)
Winky Dink 08-12-2015 09:36 PM
I’m restoring a GE Model F-80 radio (c1938) which has had a lot of repairs done--perhaps shortly post-war as parts became available ( “10/31/46 is penciled on the chassis). I need advice on one of the IF transformers.
Here’s what the third IF transformer looks like. I’m guessing that the burned dog bone resistor is a replacement part, but the schematic also shows a second mica capacitor.
https://lh3.googleusercontent.com/-y...%252520212.JPG
Below (left) is the original schematic with my re-drawing of the current status (right).
https://lh3.googleusercontent.com/-y...%252520209.jpg
So, should I restore to the original specs--replacing the dog bone and adding the missing C-28? If I add the missing C-28 I’ll replace C-27 as well, but what should I use as replacements. I have available 500V silver-micas, 630V polystyrenes, and 1KV-6KV ceramic disks.
Thanks (but be warned that I’ll be asking about the dreaded Candohm resistor at some future time).
Winky Dink 08-15-2015 03:29 AM
Brilliant Move?
(Replying to my own post... Is this a sign of early dementia?)
I decided to use the configuration on the schematic and replace the 250pF mica cap which tested about 300pF, so I fabricated two new 250pF caps using 100pF and 250pF 500V polystyrene caps.
https://lh3.googleusercontent.com/-u...%252520211.jpg
Intuitively I avoided placing the components between the coils. This little job took me a full three hours, but that included the time it took to fix the coil connection that I broke and to replace the terminal that I broke on the underchassis side of the transformer.
https://lh3.googleusercontent.com/-I...%252520213.jpg
