thrift store video projector find
2 Attachment(s)
Hello All, yesterday i found a JVC DLA-m15u video projector, it had been sitting for about a month, before i pulled the trigger. I looked up the price of a new bulb and the sticker shock is intimidating, $1090 for a bhl-5001 bulb. They let me test it and sure enough it lights up fine. "for now". The thrift store used a sneaky technique to make me buy it. they priced it at $25 + tax. I got it home and it seems to work fine, nice picture but one little problem, it is missing the remote. the remote sets up which way you wish to set it up. ceiling mount vs desk mount, front/rear projection. right now it is set up for ceiling mount which looks upside down if you set it on a desk. does anyone here have a source for jvc remotes, it uses a rm-m10g remote. and i could use some slightly used bulbs at discounted prices. I think there is a bulb that fits into the cage assembly that might be found for less money.
Mike |
Unfortunately, that unit uses a ceramic/metal concentrated arc lamp more along the lines of a piece of medical/industrial gear than a consumer projector. But you can do a lot better than the price you found:
http://www.luxtel.com/cl1487 As far as a replacement remote, they are somewhat scarce, but available at a price: http://www.movesurplus.com/product/j...-dlas15u-d-ila |
You should be able to access the setup menu from the control panel on that Projector, most of the earlier LCD Projectors had setup and menu access via the onboard control panel.
Nope, there is a basic set up menu using the buttons on the projector, but the advanced settings required the remote. I even found a copy of the owners manual online that confirmed it. A few weeks ago i got a remote on the bay for $20 + shipping.
It was marked Hughes Jvc instead of just Jvc but it works the same. I found some bulbs on the bay but i'm hopeing the seller will reduce the price some more. he has 7 of them in a lot. It is a good price for all of them but $360 is a little much to invest in a 12 y/o video projector, that may croak in a couple of years. It works well, great picture. Unfortunately the only place i have to project a image is the ceiling, I have a recliner chair i put back and watch "Ceilingvision" lol. It has some small internal speakers and luckily all of the air vents and cable connectors are on the sides. |
The solution to all lost or missing remote problems is a dirt cheap URC/UEI universal remote and a programming cable... :)
http://www.hifi-remote.com/forums/ |
Great deal. I curb found a Mitsubishi projector years ago as I was moving into my house.The bulb timer inside ran out of time on the bulb .I looked up the bulb online and they wanted about $450 bucks for it.I end up finding the service manual on freeservicemanual.net and found out how to reset the bulb timer.After figuring that out and the unit fired up and project a crisp picture on the wall.That was 6 years ago and its still working.
The guy on the bay with the lot of bulbs didn't respond to my message. so i might let it run till it croaks. |
I haven't researched much on regular bulb to LED conversions.Probably expensive. There must be some mods out there for converting these older projectors to use LED bulbs. |
| All times are GMT -5. The time now is 07:35 PM. |
