-   Antique Radio (http://www.videokarma.org/forumdisplay.php?f=16)
-   -   Does anyone have Sams folder 6? (http://www.videokarma.org/showthread.php?t=265466)
Kamakiri 10-14-2015 10:12 AM
Working on a train wreck of a Westinghouse H-122 for a friend, and there are two resistors that are charred beyond recognition. This radio was really used to death. It's Sams 6-35.
First resistor is between pins 2 and 3 of the 25Z6
Second resistor is off of pin 8 of the 25L6
Much appreciated if anyone's got the info! :)
Findm-Keepm 10-14-2015 10:43 AM
No, but Nostalgia Air has the Riders:
http://www.nostalgiaair.org/Resources/095/M0024095.htm
Looks like a 22 Ohm between 2/3 on the 25Z6, and a 91 ohm on the 25L6 cathode (pin 8).
Captainclock 10-14-2015 09:10 PM
I might have it, but not sure (the model of radio you're working on sounds familiar) I'll dig through my sams photofacts and see what I come up with. :yes:
Kamakiri 10-15-2015 05:42 AM
Brian's got the needed info, thanks though! And thanks Brian, you came to my rescue once again!!!
Captainclock 10-15-2015 07:40 AM
Alright, thought I'd offer.
DavGoodlin 10-15-2015 08:37 AM
That is one interesting circuit. The 25Z6 could have been used as a voltage doubler rectifier. Instead the cathodes and plates were parallel to increase current capacity.
I got one of these a long time ago and recently got a very similar H-247, both are missing the companion record players :sigh:
