Have some odd variations from schematic
3 Attachment(s)
I picked up an airline 94BR-1535a and have recapped it. I also replaced missing tubes. AM works fine but FM is just static. I started digging deeper and noticed a couple of irregularities. T7 has a small cap bridging one side and what looks like a dog bone resistor bridging the other side. Can't find this on the diagram. Anyway, the resistor tests open. Was this some repair or factory adjustment? Also, from T9, there's a 3.3m resistor where c22 is supposed to be. Did someone mistake a color coded cap for a resistor? I've reinstated c22 and AM seems to work better. I've also ordered new FM tube 6au6 for kicks.
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
What you are describing for T-7 is silver mica creep. What looks like a dog bone resistor, is a ceramic cap. more than likely you have at least one more transformer with silver creep. If you have a signal generator try to feed a 10.7 megacycle signal through. Using a signal tracer try to follow the signal till you lose it, then start testing parts in that stage. All the best, Tom
How about posting a pix of the under chassis area of the transformer in question? All the best, Tom
Ok, It was actually T5, not T7 bit the same applies. The brown cap on the left was removed while I tested it and was replaced with longer leads due to the tight space. The ceramic "dog bone" is on the left.
http://uploads.tapatalk-cdn.com/2016...7c17a10503.jpg Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Thanks. I'll leave it be. Going to wait on a new tube before doing much else. Been tracing the schematic tonight just to verify everything is where it's supposed to be.
True. I actually knew that but didn't think to apply it.
I put this radio aside for a while but went back to it today. Discovered totally by accident that if I leave the 6AL5 fm detector out, I can tune in some fm stations. I have it wired according to schematic but I am curious about the 10uf cap with the + side to ground. I have an extra tube which supposedly checks good so I should be OK there. Any thoughts?
http://uploads.tapatalk-cdn.com/2016...706d2993a9.jpg Sent from my SAMSUNG-SGH-I337 using Tapatalk |
| All times are GMT -5. The time now is 03:02 AM. |
