-   -   Capehart 3001B A4 series (http://www.videokarma.org/showthread.php?t=268701)
EdKozk2 03-18-2017 01:43 PM
4 Attachment(s)
I plugged in this set since the seller had. After a short while the partial raster faded away. I was suprised it even worked in the first place. The selenium rectifiers started to stink, so just turned off the set. It will need to be recapped and rectifiers replaced.
I found two litle brown painted copper boxes connected in line with the original power cord. One inside the set, the other outside. The inside one also has a 300 ohm twin line going into it. Has anyone ever seen this before? I was wondering if this may have been a motel set ?
Boobtubeman 03-18-2017 03:08 PM
Reminds me of those AC line antennas..
SR
Kevin Kuehn 03-18-2017 11:49 PM
Definitely looks like an antenna hookup to the AC line. If this was a motel set I wonder if there was ever such a thing as carrier current distribution for TV? I know they used it for college dorm radio station distribution. :scratch2:
EdKozk2 03-19-2017 12:18 AM
You now Kevin, you maybe on to something. The set was found in a storage locker in Valparaiso, home of Valparaiso University. I remember now that you and boobtubeman mentioned it, seeing an article years ago about piggybacking television signals on power lines.
EdKozk2 06-23-2018 12:31 AM
1 Attachment(s)
I finally got around to recapping the Capehart, after a Zenith 23G22 combo and RCA 34b chassis sets. I opened those power line boxes for a look.
dieseljeep 06-23-2018 10:03 AM
I've seen a few of those Capeharts and they all had one of those line filters. Maybe it was one of those selling gimmicks where "Our set filters out unwanted interference that may come through the power system".
The set itself looks like a GE clone. :scratch2:
EdKozk2 06-23-2018 05:07 PM
4 Attachment(s)
Interesting :scratch2:, This set could maybe use some more power line filtering. Half the set is hot chassis with a voltage doubler. The RF/IF section uses a power transformer and is half wave rectified. The filaments are split between 2 individual transformer filament secondary windings a the third is in series across the 120 VAC mains.
I had to replace the 300 ohm twin lead to the switched HI-LO band capacitor tuner. The set seems to pick-up/ interference , more so than any set I've repaired so far. Placement of the antenna lead almost seems critical.
This is the first old set I encountered with a DC coupled vertical oscillator.The connection is from triode 1's plate to triode 2's grid of a 6SN7.
The schematic is in Rider's 4-14 and and a similar schematic is in Sam's 99A-2.
